Stamp Plot problem
Hey,
I'm having a problem with the process control macro's in stamp-plot.
The first couple of macro's (light level ect.) worked fine, but as soon
as i went into the transistor part of chapter 3 i have the following problem:
I download the program to the BS2, the debug terminal shows output like:
%1
[noparse][[/noparse]255,*,.0196]
And the 255 changes while i turned the potentiometer, or did something else to affect the circuit.
So the output seems correct.
Then i start stamplot, load the macro, select com4 and press connect in stampplot, i see its connected and recieving info
but the yellow field that is supposed to tell me the voltage (in the macro) goes black, and it does nothing, no plotting, nothing.
Its like that for all the chapter 3 and chapter 4 macro's.
There is no real error either, apart from the occaisional "port overrun" error.
What have i tried:
- Updated to the latest version of stampplot from the website, instead from the version on CD
- Tried XP (i'm using Vista)
- Tried other physical USB port
- Downloaded Datamonitoring.bs2 from parallax website to make sure it wasn't a typo or anything
The only thing i can't explain that happends if i download a program, the debug window shows a "y" with 2 dots on top in the send window, and this also appears in the recieve window, only at the start and only once.
Anyone can give me any tips as to what could be causing my problem?
%1
What have i tried:
When running StampPlot Lite, are you also running the Debug Terminal in the Stamp Editor? If so, this may be the cause of your problem. Both programs cannot access the same COM port simultaneously. When you want to view data in StampPlot Lite, be sure to close the Debug Terminal before clicking "Connect" and "Plot Data", or else the program will ignore StampPlot Lite and print the results to the Debug Terminal.
Hope this helps!
- Jessica
Jessica Uelmen
Education Department
Could you do me a favor and pop open the Log (Immediate/Debug) window in StampPlot, Select the Analog, cntl and POBJ checkboxes, and collect a little data? I'd like to see how it is interpreting the data. It doesn't copy and paste, but if you could use alt prnt-scrn on your keyboard to capture an image and paste into paint.exe then post I'd very much appreciate it.
Which activity and macro are you using specifically?
If the color of a box changes color, it usually means it is trying to interpret the data incorrectly. It happens sometimes when I'm setting up code, but I've not seen an issue with Process Control code before.
Martin Hebel
Thanks for the advice Martin, i will do this as soon as i get home, which unfortunately isn't until 10PM GMT, and post the results here.
Currently i am at activity #1 in chapter 4 (Testing Opto reflective switch)
The macro i'm using is: ..\Macro\SIC_PC\Ch4\sic_pc_opto_plot.spm
Previous (Chapter 3) macro's using the output from "datamonitoring.bs2" give exactly the same problem
For the record, there is no plotting happening on the background, the "gauge" on the far right (with the needle going up and down with the voltage) is working tho.
Hope this helps.
Ok, the issue is that you are using number set that is not US, where 100 * .0196 would equal 1.96, but your system shows it as 1,96.
StampPlot uses comma delimited data and it is reading the value as 1 and then 96 - which will not be used properly and will cause objects to change settings, such as background text.
While I've dealt with this issue recently on some special builds, I can't recall if it's in the normal release or not.
The simplest fix is to change your number system to something with decimals.
Control Panel --> Region and Language and select English (United States).
It only came to my attention a few months ago the "," issues with numbers. I'll see if I can find a fix to correct at least in part.
-Martin
I've posted an updated EXE file here that should fix the comma-value issue.
http://www.selmaware.com/stampplot/sp_test/home.htm
You will need to unzip and replace the EXE in your current StampPlot directory.
Please let me know if helps.
Sincerely,
Martin Hebel
We indeed use the , for our decimals.
Your modified exe seems to fix it, (just a quick test before work).
The VCE field is properly updating, there is just no plotting happening but that could also be related to the activity, i had no time left to grab the book to check.
Once i get back from work i'll test with more activities / macro's
Thank a lot for the help [noparse]:)[/noparse]
Post Edited (rme_2001) : 2/11/2009 9:50:39 AM GMT
I believe you are on experiment where you need to click the button to plot a point, but be sure to check out a normal plotting one as well.
-Martin
Tho i settled on your first advice: Changing my locale setting in my OS to English(US).
Mainly because the dev .exe you shared, gave some strange issues when the plot shifted the plotted line hit the max value (10) up until roughly the time when the shift happened and then continues correctly. This happend using the macro sic_pc_data_monitoring.spm
I don't want to seem ungratefull, but i thought the above might be of use to you.
Anyway, my issues are resolved, thanks again for the help.
-Martin
Martin
Also, if you are using a USB adapter, is it a parallax one?
Martin
-Martin
