Detecting Battery Level
I'm building a small little robot that uses a 9V rechargeable lithium battery to power itself with a basic stamp as its brain.
I'm wanting to add on to this a small solar panel i'm making out of a bunch of solar cells. Depending on how many cells i include and what not i can get a peak of about 18 watts out of the cells; depending on how i wire them up and how many i include i can get 9 volts and 2 amps out of them more or less when there is good light available.
What i'd like to do is hook this solar panel up to my 9 volt battery to charge. My understanding on charging the 9 volt lithium cell is that i will need to supply at least the 9 volts to charge it.
So then i get more or less how to wire it up to charge. The part i need help with is how to monitor the charge level to stop charging when the battery is charged up.
What i was thinking is that i could use an ADC to read the voltage levels coming from the battery and if it dropped below some threshold, to then switch on the charging.
Alternatively, maybe i could just monitor the 5 volt regulated power powering the stamp. Then, if it dropped below some threshold, i could switch on the battery charging.
I also know there are chips out there that will handle all this for me, with no need to involve the microcontroller. I'm a bit confused as to which one would be right for my job though (i'm a bit of a noob with all this). I need it to be breadboard mountable and be able to handle charging a 9 volt rechargeable lithium battery (energizer). And preferably be easy to wire up.
Any help / ideas here would be much appreciated. Thanks!
Post Edited (hiskeyd) : 2/9/2009 3:42:02 PM GMT
http://forums.parallax.com/showthread.php?p=760066
It monitors the battery voltage by using a small power LED and a
simple CaS photocell.
The Bat Penguin has a
battery monitor using
the existing board.
humanoido
Post Edited (humanoido) : 2/9/2009 3:56:26 PM GMT
http://psn.quake.net/eco8/battery_monitor.html
http://www.evconvert.com/article/led-bargraph-battery-monitor-part-2
This is a very neat idea. Please, let us know what you come up with and what parts (and where from). I was thinking to switch to rechargable 9 volts for my protoboard bot, if it could charge itself, all the better.
- Stephen
I'd like to avoid the lithium "battery flaming" problem, if possible
Anyways, I found one circuit that did it with one of these chips and was pretty simple to wire up, but was for a 1 cell AA style battery and peaked at 4.5 volts, so it wouldn't work for charging the 9 volt. I looked around for one that would work for higher voltages on digi-key, but was a bit confused on their descriptions and what not.
Also you can try these links as well. [noparse][[/noparse]url]http://www.discovercircuits.com/B/batt-chrg3a.htm
Hope this helps you.
Jax
If a robot has a screw then it must be romoved and hacked into..
Here's some links that may help out-some even have links to the data sheets...
http://www.batteryspace.com
http://e-lectronics.net/liion-rechargeable-batteries-c-51_36.html?osCsid=f6e03adf879088cf880e3c9b582d390d
or just use google to help find more info...hope this helps...
-dan
If its shaped like a regular nine volt battery then it is likely 7.something... 2 i think.
Here's a nice AC recharging station for your batteries. I will find another good circuit for you for low level detect on your robot.
Jax
Add-on here is a curcit that I made for another robot to monitor it's batteries, change it at will if you like..
Post Edited (GWJax) : 4/4/2009 7:28:13 AM GMT
