new user of basic stamp
Hello all
I am a new user of basic stamp, so please if somebody can help me.
I have a project there I will have to know in with direction·I see with a camera.
I can not use any magnetic sensor because i will look down in a 20 meter long pipe, sometimes of steel ( the pipe is vertical).
I can calibrate the camera (in witch direction it points) before I send it down in the pipe.
Then I will know the new direction when·I rotate the camera down in the pipe.
Is there any how can help me with a program to and what device is best to go on.
Anders
Post Edited By Moderator (Joshua Donelson (Parallax)) : 2/19/2009 5:25:39 PM GMT
Anders
Parallax Engineering
Did you find any solution? if you did Please share.
An hour's contemplation is better than a year's adoration.
http://forums.parallax.com/showthread.php?p=784261
What is the diameter of the pipe?
Tom Sisk
http://www.siskconsult.com
Or you could put the polarized sources on the camera, shine them up the hole, and do the sensing at the top.
If you're sensing at the top, three light sources could be of three different additive primary colors and you'd merge them and observe the resultant color, which would give complete information.
Or you could use a long Bowden cable from the camera to an angle encoder of some type at the top of the·hole, so that turning the camera would mechanically actuate the detector.
Or you could equip the camera with an encoding gyroscope.
I'm sure there are many other ways to do it.
· -- Carl, nn5i@arrl.net
It is not so easy.
The problem is, I have the camera in a more than 20 meter cable. ( I can't se down because it can be some small bend of the pipe) When i sink it down in the pipe the camera head are rotating because the wire is not in an right angel.
I must se how much it rotates while I get it down in the pipe. If I can get a reference position when the camera is up I will have the differences angel when its down and then I can say how many degree offset this will be.
I can not se anything than a Gyro that can take care of the angel.
But how to process the signal from the Gyro??
Hope that anyone have a solution for me.
Anders JATK
