Why use true logic in the RFID card reader? — Parallax Forums
william chanwilliam chan Posts: 1,326
edited 2009-02-09 17:59 in General Discussion
All PCs use inverted logic.
So if the serial RFID card reader uses inverted logic instead of true logic, we would be able to connect it directly to a PC with just a couple of resistors.
What's the logic behind using true logic?
www.fd.com.my
www.mercedes.com.my
    edited 2009-02-09 01:46
    William,
    If you want to connect the Serial RFID Reader to a PC, see this:
    http://forums.parallax.com/forums/default.aspx?f=21&m=180521
    If you're asking a design question it probably will not be answered, as the engineer doesn't frequent these forums.
    PCs don’t use inverted logic…the serial port simply uses inverted baud mode as a result of the RS-232 drivers, which inherently invert the signal. Of course, it is typically inverted again on the other side resulting in a once again, true (non-inverted) signal. Microcontrollers typically work with these signals, and if you open an external modem up you’ll see they also have inverting drivers to convert back to the non-inverted signal. I have a Hayes compatible at home with 1488 and 1489 line drivers in it. The computer it came off from (80286) had the same drivers on this inside. Take care.
    Parallax Engineering
