unused pins starting issue
I have build a circuit·which uses·a programmed·BS2PX24 and it is on its own board.··Sometimes the thing does not start up right.· I have three boards built up and they are programmed differently and they all seem to exibit this issue randomly.· Switch the power off and on and it often comes on on the second or third start try.· Then runs fine (Except if using sleep commands) but that is a seperate issue.··The board is etched (express PCB)·and soldered, so I do not suspect the construction (Socketed·stamp).· ·The program is pretty·simple and I do not suspect it. ·Does anyone know what·is the·recommended way on the board to terminate unused pins like the programming pins, reset, and bypassing?·· I have no programming interface directly on the board,·i.e., cap's or transistors for connection to programming or debug.
I am suspecting
Thank You,
Walt,
I am suspecting
Thank You,
Walt,
Smile ... It increases your face value!
4 AA batteries, with LDO linear M2940CT. input of Low drop out regulator is 220 uF, output has two 1000 uF caps. These are within 1/4 inch of LDO and Vcc traces to the stamp are less than 1 inch, approx .050 inch wide. The ground is full plane, filled top and bottom of board where there are no traces. I will be putting in a a .01 or .001 on the power lines for the stamp Vdd pin to ground and also the Vin pin 24. Raw battery power (6 Volts) is applied to the vin pin and regulated power from the LDO is applied to the Vdd pin 21. Reset pin is not connected on stamp, nore are the three programming pins, 1,2, 3.
I connected my external LDO to the Vdd pin on 5 volts. Now looking at this, not sure if it is necessary or not or a good idea. Maybe it should be isolated. Thinking about it I might be able to scrap the LDO regulator and run off the stamps regulator. The stamp may have sufficient power for the circuits on one of my boards, but not all of them as the LDO regulator has a 10 ma idle current.
Walt,
Try powering your project from a more robust source, and see if that helps with the reset problem.
Tracy Allen
www.emesystems.com
