PINK and BS2
I have finally got my PINK up and running.· I was having power problems with a HomeWork Board. The PINK works through the web interface, and I can run the PINKTestV1.bs2 code with success.· But I cannot run any of the other sample bs2 programs.· I get a timeout everytime.· The only difference I can see is the nbvar variable is set to byte in the PINKTestV1.bs2 code and byte(16) in the other sample programs.· Any help or ideas?·
The homework board is most likely not able to provide sufficient current to power the PINK Module. This is especially true if you’re powering the H/W Board from a 9V battery, which itself could not provide adequate current to the PINK Module.
Parallax Engineering
