what am i doing wrong — Parallax Forums
russ christensenruss christensen Posts: 84
edited 2009-02-08 18:00 in Propeller 1
ok guys, i have no idea what i'm doing wrong. last night i had a nice simple setup on the ppdb, had the clock running feeding time to the vfd, had the ds1620 feeding it temp, using the fullduplexserial driver to send it data and everything was wired up and working great. i took the vfd off the board last night before i went to bed, and put the ppdb in its antistatic case. this morning i put everything back together just like it was last night, and now i am getting no display whatsoever on the vfd. i've tested voltage from the 5v, i have it, using the ground on the ppdb, i even hooked up a voltmeter to the output pin on the prop, and i'm getting around 1.5v i am assuming because its just not sending any signal atm. does anybody have any suggestions? i've already fried (i think) one ping sensor which i'm getting ready to send back to parallax. i can't be replacing parts (especially expensive ones like the vfd) every week cause i do something stupid. any idea's or recommendations would be greatly appreciated. sorry for my extreme lack of experience and feel free to let me know if i'm breaking fundamental electronic laws.
Russ
  • JonathanJonathan Posts: 1,023
    edited 2009-02-07 23:51
    Some suggestions:
    Check power again, make sure all grounds are OK. VFD's use lots of juice, so check batteries if you are using them.
    Verify the correct program is loaded into eeprom. Maybe it was only in RAM.
    Double check your connections. Look at where the wires are attached too.
    Test the VFD power on the VFD itself.
    Make the Prop cycle the pin you are using, 1 sec on/off. Check that it is getting to the VFD too.
    If the VFD has a test mode, try it.
    Jonathan
    www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
    edited 2009-02-08 05:29
    russ christensen,
    Can you post a schematic? ...or take (a) clear closeup picture(s) of your setup?
    Also, please provide the code that you are running as well.
    Beau Schwabe
    IC Layout Engineer
  • russ christensenruss christensen Posts: 84
    ya i can, i just have to find my camera. can't do much robotics stuff today because i have an assignment due tomorrow, but i'll try to get some pics up tonight.
    russ
