Prop Plug and BS2
Prop Plug and Stamp
Has anyone used the Prop Plug to program the BS2? The information on the Parallax site suggests that it can be used for that purpose. The four outputs, VSS, RES,TX,RX are clearly labeled. Would the connections to the BS2 be the following?
VSS = Pin4 (VSS)
TX = Pin2 (RX)
RX = Pin1 (TX)
RES = Pin4 (ATN)
MikeS
VSS = Pin4 (VSS)
TX = Pin2 (RX)
RX = Pin1 (TX)
RES = Pin4 (ATN)
MikeS
- Rick
http://forums.parallax.com/showthread.php?p=567989
Parallax Engineering
Thanks for your input.
MikeS
Courtesy of Solarbotics, assisted by Parallax technical support member Kevin.
