Keep peak input value
I am working on a unit to monitor g-forces in a car using a BS2 and the Memsic 2125.· Good news is that I had no problems getting it to display the tilt and·g-force for·X and then modifying it to read Y and display them on the 2x16 serial LCD.
Found a flaw in the design... it's·hard to drive and read an LCD at the same time.
So, how can I temporarily keep the peak value?· I don't see anything in the commands that would do such a thing.· I don't really·need it to be a data logger, just hold on to the peak value until·a button is pressed (or a few seconds or·whatever pass).
Project based on N&V #92
IF ButtonPressed THEN PeakValue = 0
(though I read the MIN command I did not understand that it could do this until you posted)
