Output pins
Can one drop a 5 volt·dc onto a pin that was made to be a output pin without hurting a BS1.
The reason I ask such a question,·the project that Im building I need to use·six BS1 output and·six·switches
to make the my project work as in auto and manual mode.
· -- Carl, nn5i@arrl.net
Can you attach a schematic drawing of what you're trying to do? It may be that a similar resistor is all you need, maybe 330 Ohms. What's the output controlling?
Here is a small part of the schematic that I made for you.
Please note that it only shows one output and one button all other are the same.
Readers
I don't understand what you're trying to do with the 100K resistor. I would suggest putting a 330 Ohm resistor between the Stamp I/O pin(s) and the switch. Normally the Stamp will drive the 4013 and the 7404. When you push the pushbutton, the switch will override the Stamp. If the Stamp is expecting this to happen, it can set its I/O pin to input and read the switch setting. The 330 Ohm resistor is only about 3% of the value of the 10K pulldown, so it shouldn't have a significant effect on the logic high voltage for the 4013 and 7404 since it forms a voltage divider with the 10K resistor.
Can I not install a diode in series with the lines from the output pin to stop this from happening?
readers
Listen to Mike. Answer his question and do not try to over engineer a circuit. Mikes simple answer to the major problem of your circuit will work correctly as you want it to. I also do not know what the 100K is for?
Dave...
Dave W.
