Audio/Video RCA
Here's a quicky. If I'm using pins 0-2 for TV composite output, can I use pin 3 for auidio output, or will the video interfere with this? I've had some PCB's manufactured, and it's an easy fix if it will cause a problem, but I don't want to have to mess with it if it's not needed.
http://www.propgfx.co.uk/forum/·home of the PropGFX Lite
dir[noparse][[/noparse]3]~~
This sets the pin as an output, which should swamp any cross-coupled noise.
Sorry for the OT post, but the need for it will shortly become clear. I need an email for you to which I can send a Paypal payment and other info to you RE your boards I'd like to order. If your PM's here are full, I can't reply to your generic PM of the 5th.
I look forward to the boards.
Thank you, Tom Perkins
