Questions about etherx card, webserver games, etc.
I perused the manual and have some questions about etherx and something else...
Extent of relevant knowledge: I have not programmed the internet since I used BASIC to operate a 300 baud modem with a TS or UNIX account. But I have made some web pages with HTML since then.
Questions: (Generally speaking, assuming not simple answers...)
1.Having a domain name already, How might I make HYDRA use dynamic DNS to tell a nameserver it's current IP?
2.How to get data from an extended URL, to parse it? These would be pseudo examples of extended URLs:
"www.mygame.tld/gamename/gamelevel00001" or
"www.mygame.tld/?&game=gamename_level00001" or
"www.mygame.tld/tictactoe=xox oxo ---" or something like that.
Maybe that way many people could play a game without filling up the HUBRAM by way of storing their gamestates
only in the URL itself, with game objects in the web browser having URL links to gamestates caused by clicking them,
and the HYDRA only needs to know about a particular game while it is serving and processing a state change.
A spin program would arrange and serve new HTML in response the those gamestate URLs,
and probably also have small prepared image files of gamepieces to serve from SD or eeprom.
Theoretically, it should be able to play a large number of simultaneous games (players) that way, methinks.
3.Dumb question: Could the SDMAX and ETHERX be connected at the same time? (I was just too lazy to look it up myself)
4.Dumb question: I broke the SD card connector on my SDMAX and it is currently held together with sticky tape.
From what source and part number can I replace it and then resolder it myself?
I also want to get another (SD card connector) for my proto board.
Post Edited (VIRAND) : 2/5/2009 1:21:12 AM GMT
Hopefully someone who knows a lot about web servers and how they handle extended URLs can help you with question #2.
Concerning question #3, without some hardware hack/modification SDMAX and ETHERX cannot be connect at the same time. There is only one expansion slot. You could make a cool PCB that plugs into the expansion slot which would run the signals out to multiple slots but it would require additional circuitry so that you determine which card you are communicating with (things like tri-state buffers). That way multiple cards won't drive the signals at the same time.
Try and ping on Andre' about question #4.
Hope this helps.
Just to clarify,
I want to make the HYDRA WEBSERVER into a game.
I want to rent the domain "www.thenameofmygame.com". (This I know how to do.)
I want the HYDRA WEBSERVER to boot up,
*---> and figure out HYDRA WEBSERVER's own IP,
*---> and tell it to the nameserver for "thenameofmygame.com",
so anyone can play THENAMEOFMYGAME by typing "thenameofmygame.com" into their PC browser while my HYDRA is on.
I don't think that the HYDRA WEBSERVER needs to look up any URL's because the player's browser does that.
I think that for people to play my HYDRA on my website, my HYDRA must be able to tell my domain name server it's IP.
(And question #2 is just asking if and how an idea for using the browsers of x number of players to communicate
gameplaying information with a game based on HYDRA WEBSERVER without using up it's memory and sockets ... might work. )
It might be awhile before I get around to doing what I'm thinking of doing,
but that is OK, a few of the people on these forums are quicker than myself,
and I ask on behalf of everyone, and I submit my idea on behalf of everyone,
because if it works, it would be super easy to make a wide variety of game websites
this way compared to any other way that I am aware of. For example:
If HYDRA can play chess (why not?) then it could play against 100 people at the same time,
just by responding to 100 URLs representing chessboards with 64 extra characters
with HTML chessboards whose squares and chessmen icons have links indicating
intent to move them when they are clicked. (hmm. Might require two clicks to move?)
And it should even more easily play a Myst-like game, in which you could move by
clicking on a pre-served tile image that may clearly indicate moving in a direction
(left,right,forward) by the position of the tile in the served scene, or, if the tile
contains the image of a useable game object, the game will respond with the
visible effect of collecting or using the object, and any player's browser would
send the game state in the extended URL in such a way as to indicate the player's
position in the world, direction facing, objects already collected, and especially
what was clicked on. Everything that can be clicked on has it's own pre-generated
URL which includes the previous game state and the future game state which was
anticipated and included in the previously served HTML which generated the
current scene in the game of one of several players who are playing it on their browser.
I don't think this is as hard as it sounds. I've made games like that before, and I'm thinking
of renovating one of my websites to be like this kind of game, in HTML even without the HYDRA.
(The hardest part would be pre-rendering all the scenes and breaking them into pieces that should
do something when clicked on. On the HYDRA all those images would have to be stored on an SD card,
after, most likely, being drawn with PC art software.)
I have not thought very far into the idea of making HTML-based games, especially where they
have a world, ESPECIALLY not about methods where multiple players would be aware of each other
and be able to communicate, since my current idea is supposed to work without the HYDRA
"knowing" anything about the players (which would require keeping track of them in it's memory).
With my idea of using extended URL data to keep track of each player's game, two players with
computers who could actually see each other in real life could be in the same place in the game world,
and if one takes an object, it would still be there for the other player to also take, until he takes it.
That makes more sense if both players were playing chess against the HYDRA. Each player only knows
what moves were made in his own game, which only exists on his own browser screen. At this point in
time, my idea only covers games that from the player's point of view are single-player games against
the HYDRA WEBSERVER. I don't have any ideas for making HYDRA WEBSERVER based HTML MMOG's yet.
I don't even know if this method would work yet. If it does, and is any good for fun, use it!
Hopefully someone on the forum who knows more about DNS servers will be able to help.
I think I've seen this way done before but not sure how it is done exactly. <--(edit:automatic redirects)
The HYDRA should FTP to my (hypothetical) host server at www.mygame.com/index.html
and upload a small page of HTML (edit:with a link to my HYDRA IP address) saying:
____________________________________________________________________
Welcome to MYGAME.
Please click "here" to connect to my HYDRA. <---This is for illustration purposes only so don't click.
If nothing happens soon, I'm sorry, my HYDRA must not be on.
_____________________________________________________________________
(A link to HYDRA from a hosted page can be quickly updated even if the DNS servers can not, right?)
(This will require learning something about FTP that probably isn't in the manual.)
(I have also seen web pages do the "redirect" automatically after a few seconds but I'm not sure how.)
Post Edited (VIRAND) : 2/9/2009 2:49:36 AM GMT
http://www.dyndns.com/developers/specs/
I haven't checked this out yet myself. But I saw your post and I thought I would look around because now I'm interested in that, too. I've never looked into the details how it is done because my router has always done that for me. Or I just downloaded their Windows-based updater for my laptop.
It would be cool to try that out on the Hydra. I'm not sure why you would need that though other than for experimenting. Couldn't you just update your router and then point your game traffic to the hydra through your router's configuration?
Jeff
but my ISP for internet access often changes my IP when I boot or when the modem power is interrupted.
I think it sounds like a great idea to ftp a link page to www.mygame.com (or whatever) from my Hydra every time
it powers up as a game server and gets a new IP address, if possible.
