play avi videos ( or any format ) on the prop from a usb flash drive — Parallax Forums
nemesiswesnemesiswes Posts: 17
edited 2009-02-04 19:29 in Propeller 1
is it possible to play avi or any format video from a like a 4GB or a 16GB usb flash drive and then play that video from the device onto eithier a lcd connected to it or like to a tv????????????
  • Jay KickliterJay Kickliter Posts: 446
    edited 2009-02-04 02:05
    No, for that you'll need more specialized DSP hardware.
  • nemesiswesnemesiswes Posts: 17
    edited 2009-02-04 02:28
    do you have any idea where i might be able to find something that can.
    does parallax cary anything that can do it,
    later
    edited 2009-02-04 04:49
    The most likely solution for you would be to get an inexpensive iPod that can do video output and find some information on the Internet for making your own remote control for it using a serial I/O device. A Prop could then produce the remote control sequences needed. I don't have any links to that sort of information, but I've seen it before on the internet.
  • mparkmpark Posts: 1,336
    edited 2009-02-04 07:33
  • AleAle Posts: 2,363
    edited 2009-02-04 09:26
    Those are specially crafted files, not out-of-the-box avis (well avi is not a format, just a container). There are some ARM processors with SMID extensions that are able to do what you (may) want. Especially if full color and better than 128x96 (or so) resolution is needed.
    if what you saw on those videos is enough, them the propeller may be a candidate.
  • BaggersBaggers Posts: 3,019
    edited 2009-02-04 10:50
    Thanks for the page mpark [noparse]:D[/noparse]
    nemesiswes, those vids that I did, were converted from AVI's so yes can "technically be any avi" ( pre-conversion ) to a format that I used for the PropGFX add-on for Hybrid, as the Hybrid has SD built onto the board, ( for retreival of the video from SD card ) so yes it can be done, and plays to composite AV, with mono audio.
    but if you want decent quality ( as that image is 128x96 pixel resolution and propeller colours. ) you'd be better off going for an iPod or ARM if you want to do the programming yourself.
    It's really down to what quality you're happy with like Ale said [noparse]:D[/noparse]
    http://www.propgfx.co.uk/forum/·home of the PropGFX Lite
    edited 2009-02-04 12:41
    There was also deepfry. Fits the "any" part of your request.
    http://forums.parallax.com/showthread.php?p=731755
    OBC
    New to the Propeller?
    Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
    Got an SD card connected? - PropDOS
  • william chanwilliam chan Posts: 1,326
    edited 2009-02-04 13:26
    Will the Prop2 be able to do this in full color?
    www.fd.com.my
    www.mercedes.com.my
    edited 2009-02-04 15:04
    I'm sure it'll be more than capable William [noparse]:D[/noparse]
  • RaymanRayman Posts: 16,379
    edited 2009-02-04 16:04
    I bet you could play uncompressed AVI at TV resolution from Flash using a bunch of external ICs...
    I'm working on a 320x240 TFT driven by a Prop that I hope will able to play full screen video with audio from SD.
    But driving TV or VGA is more difficult because you have to have the right timing...
    edited 2009-02-04 16:08
    Cool Rayman, which TFT? got any pics/vids? keep us posted on that [noparse]:D[/noparse]
    I bet PropII will be able to do a decent codec too [noparse]:D[/noparse]
    edited 2009-02-04 18:53
    It's a run-of-the-mill 2.4" TFT LCD with ILI9325 controller.
    PropII should do MP3 decoding, but I doubt it could do video decoding. But, we'll see...
  • CircuitsoftCircuitsoft Posts: 1,166
    If you're looking for something small that can play videos, perhaps you need a BeagleBoard.
    600Mhz ARM Cortex A8, 430Mhz TMS320C64+ DSP, and 3D graphics accelerator. All on a 3" square board that takes <2Watts for $150
    Run's Linux, has DVI-D output, and USB. I would still connect one if it's UARTs to a Propeller for external control interfaces, but...
    I'm working on making a Laptop out of mine.
