H-bridge + an inverter
I was thinking the other day... I can connect an inverter to my H-bridge and control the motor's direction
only using 1 stamp pin.
Has anyone else done this?
Did you PWM the inverted line or did you use the H-bridge's enable pin?
Did you miss dynamic breaking or was the saved I/O line worth it?
Robert
So two pins, one for enable/PWM and one for direction control.
I understand that the HB-25 is a really nice product, but its both out of my price range and overkill for my application.
I'm using some cheap ($2.35) single chip h-bridges that work just fine, I was just curious if anyone else had used an inverter to reduce the number of
pins required.
