How to limit the voltage of a signal pulse going into an IC?
Hi all,
I have an "ultra fast" comparator AD8561 that is powered at +5 volts and therefore its absolute maximum input signal voltage is +5 volts (at least that's how I understand the data sheet). Problem is, the comparator will be looking at a train of pulses that sometimes exceeds +5 volts. I don't want these >+5 volt signals to damage the AD8561, so how can I limit inputs to the comparator without dragging down the magnitude of my other (< +5 volt) signals? I'm afraid of using a voltage divider because that will not only reduce my other signals but it might also introduce other problems, capacitance, impedance mismatches, ringing, etc. All the signals will be pulses that are about 1 microsecond wide and I don't want anything that might stretch them out or deform them too much.
Suggestions or comments are greatly appreciated.
thanks,
Mark
thanks,
Mark
![smile.gif](http://forums.parallax.com/images/smilies/smile.gif)
If your comparator can actually stand a diode-drop MORE than the supply rails, then a diode to the positive rail might serve to limit input pulses acceptably. One might choose a very-low-forward-drop diode in that case.
But I wonder why you're using a comparator (an analog device) rather than a gate or other digital device.· You express an interest (as I understand it) in maintaining the pulse-length, and gates are designed to do that, having much faster slew rates at the output.
· -- Carl, nn5i@arrl.net
Post Edited (Carl Hayes) : 2/3/2009 12:03:43 PM GMT
This thought crossed my mind but I was hoping to avoid adding another power supply.
SRLM, okay, that seems reasonable to me. But what is this kind of design called? Is there a name for it? I'd like to read more about it but I don't know what to search for. (Warning: I'm a MechE, you know.
Carl, yes, I thought about using some kind of amp at Gain = 1, but I don't know how to start searching for "parts that can take my bad design techniques." And I wonder if any parts can take input signal voltages above the power supply???
Thanks, you guys, for the inputs. You are the lanterns of hope in my cavern of darkness.
Hmmm.... well, I just used what I've seen other people use on similar applications. That doesn't mean I know what I'm doing. The pulse coming into the comparator is from an analog device (a photomultiplier via an amp x10) and it uses a fast latch. If you know of something that might be better and that comes in a DIP, please do tell.
thanks,
Mark
Bean.
·The next time you need a hero don't look up in the sky...Look in the mirror.
Post Edited (Bean (Hitt Consulting)) : 2/3/2009 5:51:01 PM GMT
Edit: amazingly, I think I choose the right words to search for: Zener Limiter. Here are some of the results:
http://www.eng-tips.com/viewthread.cfm?qid=99268
http://hyperphysics.phy-astr.gsu.edu/HBASE/Electronic/limiter.html
Hi Carl. That sounds cool but unfortunately the amp is already built into the photomultiplier's module and I can't get to it.
Right now it looks like I'm going to try a combo of PhiPi's method of cranking up the supply voltage on the comparator and SRLM's zener clamp idea. I think that will give me a margin of safety while at the same time not causing me to lose too much range.
Thanks everybody!
Thanks, Phil, until you pointed that out to me, I never noticed that before. I just blithely assumed I could pump 5 volt signals into this thing and not pay a price.
cheers,
Mark
