breadboard to prototype to PCB
Once one gets to the point where they have an operational device on a breadboard with wires all over the place...what do you do with it to build your device?
I'm thinking I may grab a couple of the proto boards for the propeller just to have them anyway and use that as an interim step, but I'm thinking now about printing up the boards and building my little device, and that leads me to some questions.
The biggest one in my head right now is what style of chips to use. There's DIP (which is everything I have), then there is that smaller pin setup (2mm) and then there is surface mount (QFN / QFP). Perhaps an simple explanation of the pros and cons would be nice here.
Does it make sense, if one were to want to build 3 or 4 of a thing to go out and find/buy the surface mount (or smaller pin setup) versions of a chip? Is it possible or desirable to use DIP (the DIPs are so big)?
I'm pretty confused on this matter and would love advice before I make a decision and blow a ton of money and wait a week for delivery only to find out I made the wrong choices.
Post Edited (RICoder) : 2/3/2009 3:41:35 AM GMT
- Stephen
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto for SunSPOT, BitScope
www.tdswieter.com
Adapters are available for SOIC and SOJ parts to convert then to a DIP outline for breadboarding - I have attached a·link for an Aries SOIC adapter - http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=A322-ND.·With a bit of practice and patience you should be able to solder an SO part but soldering QFN and related small packages requires more hardware. I use a hot air system and solder paste to solder and rework the smaller devices. These systems start at $250 and can easily exceed $1,000.
Craig
Generally speaking, I noticed that when I was trying to "get it right the first time" I was not learning as much or as fast. By kluging up lots of circuits and making lots of mistakes (and observations, too), I found I learned the most. You might feel like you're wasting parts and labor this way, but I took my inspiration from the first rocket scientists. They knew that each test flight was going to crash and burn, but they cranked them out as fast as they could, instrumented each one as best they could, and learned as much as they could before the thing blew up during flight.
That said, you might also consider the PropStick USB version. It's the same size and pins as the DIP but it has the clock, volt reg, eeprom, and Prop all crammed onto one stick, along with the USB plugamabob.
my 2 cents worth
What I'm finding is my challenge now is:
a) figuring out how to solder jumpers from one pin to the other.
b) finding the proper DIP plugs to use for the multitude of ICs I'll be using. (its quite a large design)
Any help on a) would be great. Also where you got a perf board with a ground plane on it would be nice to know [noparse]:)[/noparse]
I'm basically building up a cart here and at sparkfun with all the bits I think I'll need (and multiplying by 2 so I have extras) as I make a schematic/board design in Eagle to make sure I don't miss anything. In the end I should probably be able to get away without having to solder any of the ICs or MCs to the board...we'll see.
RICoder,
I got the prototyping board with ground plane from Digikey:
search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=438-1052-ND
The picture doesn't show the gold ground plane on the other side. The holes are plated thru-holes so it's nicer to work with than the foil types, which only cover the surface of a board on one side. My particular one was 4x5 inches but they have ones much larger. One thing to keep in mind: the gold plane acts as a heat sink, so you must make sure the gold is clean and gets a good heat so the solder actually bonds to it. They have non-gold versions, but they aren't much cheaper.
As for soldering from one pin to another - I feel your pain. Sometimes it seems like I have to melt down half a roll of solder just to connect two adjacent pins. (And yet unwanted solder bridges can appear elsewhere almost magically
~~ dRu ~~
Anyway, this guy said you should push the jumper wire through from the top (like a component) and just cut it long enough to touch the pin you are connecting to, and then solder.
