PASM, what am I doing wrong?
I have this code, when I run as is, I get a blank output on the PST (the CR works fine, but no number output).
But if I comment out the PASM "function" I am not using (times10 or divide), each chunk of code works just fine. How are they conflicting with each other?
Here PASM code that works:
OR
All I did was removed the unused code.
CON
_CLKMODE = XTAL1' + PLL16X ' 80MHz clock (10MHz for frequency read, 40MHz for 9600 serial baud, 80MHz for shiftout and RFID read)
_XINFREQ = 5_000_000 ' 5MHz Crystal
OBJ
DEBUG : "FullDuplexSerial" ' for debugging
VAR
LONG retblock'[noparse][[/noparse]20]
PUB Main
DEBUG.start(31, 30, 0, 57600)
waitcnt(clkfreq / 2 + cnt)
DEBUG.tx($0D)
cognew(@math, @retblock)
DEBUG.dec(retblock)
DAT
ORG 0
math
MOV par1, #30
MOV par2, #2
CALL #divide
JMP #end
times10 MOV par2, par1 ' make copy
SHL par2, #2 ' times 4
ADD par1, par2 ' plus 1 (times 5)
ADD par1, par1 ' times 2 (times 10)
MOV ret_val, par1 ' move to return
times10_ret RET
divide SHL par2, #15 ' get divisor into y[noparse][[/noparse]30..15]
MOV idx, #16 ' ready for 16 quotient bits
:loop CMPSUB par1, par2 WC ' if y =< x then subtract it, set C
RCL par1, #1 ' rotate c into quotient, shift dividend
DJNZ idx, #:loop ' loop until done
divide_ret RET
end
WRLONG ret_val, PAR
par1 LONG 0
par2 LONG 0
ret_val LONG 0
idx LONG 0
FIT 496
math
MOV par1, #30
MOV par2, #2
CALL #divide
JMP #end
divide_ret RET
end
WRLONG ret_val, PAR
OR
math
MOV par1, #30
MOV par2, #2
CALL #times10
JMP #end
times10_ret RET
end
WRLONG ret_val, PAR
self JMP #self
or something along those lines at the end of the code, and have an infinite repeat loop at the end of the PASM. It may just be that FullDuplexSerial doesn't have time to send the output before the prop goes off into never never land.
Could that be it? I'm still pretty new at this myself, so I may be way off here. [noparse]:)[/noparse]
You could also modify your PASM code to write a non-zero value in the mem location after the ret_val, and use that to indicate that the PASM prop has finished. Then you'd actually know you got an answer, and your SPIN code could just repeat until that status value was non zero, then read out the answer, instead of waiting for a 1/2 sec.· (EDIT - I'm guessing, since you're writing ASM, that you already know this.)
Jason
