Trouble with a Math Library
Trying to map my wall with an IR range finder and the MX2125 Accelerometer. For reasons not worth explaining, I have to turn the accelerometer on it's side, and the angle will be angle := Tan(x/y). I'm printing my result out to an LCD at the moment, hoping to put it on a usb later. Things are working fine, until I try to compute Tan(x/y)...or even Tan(0.5). If I try to use the library, my LCD is completely blank. If I comment the line out, the first two numbers (x and y pulse widths) print out just fine.
I'm using the Float32 library, which can be found here: obex.parallax.com/objects/202/
Here's my code, but it works fine as long as I comment out the Tan() line.
Any thoughts are much appreciated.
Thanks.
OBJ
LCD : "debug_lcd.spin"
math : "Float32.spin"
accel : "MXd2125.spin"
PUB main
accel.start(PWM_MonitorPin_x, PWM_MonitorPin_y)
InitializeLCD
repeat
LCD.gotoxy(0,0)
'LCD.str(string("yo"))
x := accel.x - 400_000
y := accel.y - 400_000
angle := math.Tan(x / y) 'This line causes nothing to be printed on my LCD at all
LCD.decf(x, 8)
LCD.gotoxy(0,5)
LCD.decf(y, 8)
LCD.gotoxy(0,1)
'LCD.decf(angle, 4)
waitcnt(clkfreq / 2 + cnt)
Thanks.
At the heart of this is a basic fact. The Spin compiler has limited support for floating point. It can handle floating point constants and it can perform basic arithmetic on constant expressions using floating point, but it does no automatic conversions and it does no floating point arithmetic when the program is running, only during compilation. Any floating point values are treated as integers at run-time. The floating point libraries do arithmetic in floating point as function calls, but they pass around 32-bit integers which happen to contain values in floating point format.
