Soldering vs Wire wrap
I know that wire wrapping has a lot of bonus points that soldering doesn't (strain relief, easy updating, ect)
but does anyone actually use it nowadays?
Also, what's the cost like (the wire, the special sockets, ect) compared to soldering through-hole components?
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
The insulation is stripped from the end of the wire, it is fed through the adjacent hole in the perf board, and 4 or 5 turns of the bare wire are wrapped around the pin. Once the circuit is working I solder all the wires to the pins.
This would only be for a small project involving a few low speed logic chips and maybe a basic stamp or similar uc.
My work has a lot of stock of wirewrap sockets and tools, so it's easier for me to prototype things (and cheaper) than to go and CAD a PCB and get it made.
When I'm happy with my wire-wrap proto....I'll take a soldering iron and quickly flow solder on to the wraps....then clip the long legs so I can fit things in to a box.
I've got an electric wire-wrap gun, so my fingers don't get gimped by the end of it.....it's actually quite meditative, without the nasty solder smoke!
Cheers
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
Leon
I would say wire-wrapping is faster from beginning to end.
We both have to draw up the schematic. You would then go on to CAD the drawing and I'd already be building it. Unless, of course, you're using those "solderable interconnect" boards (not sure what they're called)...but then that's not making your own PCB.
Cheers
<FONT>Steve
Leon
