ser.rxDec question — Parallax Forums
ser.rxDec question
realolmanrealolman Posts: 65
edited 2009-02-01 18:11 in Propeller 1
· I have these two lines in my propeller code:
InputVariable := ser.rxDec
WhichVariable := ser.rxDec
the only variable that receives info from rxDec is the second one... doesn't matter which one it is.
If I reverse the order of the two lines, InputVariable will receive the info.
If I only have one line, it seems that the execution stops until I serially transmit something with a chr(13).
I am sending the two lines from VB express. They are both the same and they both send a chr(13) at the end.
I even inserted a delay between the two transmissions... the only one that gets any info is the second one.
what am I doing wrong?
thanks
  • DiverBobDiverBob Posts: 1,123
    edited 2009-02-01 16:18
    Can you post the rest of the code, kind of hard to speculate right now. I have been using the rxDec quite a bit and it works pretty good.
    Bob
  • realolmanrealolman Posts: 65
    edited 2009-02-01 17:00
    OBJ
    SER : "Extended_FDSerial"
    VAR
     long WhichVariable
     long InputVariable
     word Parameter[noparse][[/noparse]100]
     long MyVariable
     long Stack[noparse][[/noparse]40]
     long CountStack[noparse][[/noparse]40]
     word InputCounter
     long OldCount
    CON
     ' spin stamp
     '_CLKMODE = XTAL1 + PLL4X   ' clock speed too low = 1X=10Mhz
     '_XINFREQ = 10_000_000
     ' non-spin stamp
     _CLKMODE = XTAL1 + PLL8X    ' clock speed too high = 80Mhz
     _XINFREQ = 5_000_000
    PUB Main
     cognew (Serial, @Stack)
     cognew(CountInput,@CountStack)
    Pub Serial
    'handle serial transmissions
     dira[noparse][[/noparse]17..21]:=%111111
     ser.start(31,30,0,38400)
    'this section accepts serial input and output
    repeat
      If MyVariable <> OldCount     'if counter has incremented
        ser.dec(MyVariable)         'serial transmit count
        OldCount :=MyVariable       ' if count has been transmited, make OldCount
                                    'variable equal to MyVariable so same count
                                    'is not transmitteed over and over
      If ser.rxcheck <> -1          'checks to see if serial input.
                                    'if nothing there, returns -1
      'THESE ARE THE TWO LINES
        outa[noparse][[/noparse]17..21] :=InputVariable 'if serially input number
                                  'light LED's
        Parameter[noparse][[/noparse]WhichVariable]:=InputVariable 'load the array element with a value
    PUB CountInput
    CTRA := %01010 << 26                  'set counter to positive edge detector
                                          'shifts the %01010 over to the appropriate position
    ctra := ctra + 10                     'sets counter to use pin 10
    frqa:=1                               'must set to non zero so it counts up
    'read accumulator value and store in variable
    repeat
     MyVariable:=phsa
     If phsa=>360
     phsa:=0
    When I copy and paste this stuff here I lose the Indentations...
    I was trying to boil it down to what I thought were the important lines:
    Whichever one I have last gets the info... the first one just seems to ignore it, yet when I have only one line, doesn't matter which one, ·it seems to stop execution and wait for serial transmission to be received and get a chr(13) ... doesn't the frist line stop and wait until it gets a chr(13)?
    Post Edited (realolman) : 2/1/2009 6:05:38 PM GMT
    Please disregard, I believe I've figured it out...
    I was forgetting that the first digit I was sending serially was being "used" by ser.Rxcheck to see if there was anything there or not.
    thanks for looking
    Post Edited (realolman) : 2/1/2009 6:23:42 PM GMT
