Big Mistake ?
Ramboman
My last project has a minimum space requirement.· Having a protoboard, I decided to use the center part only.· Unfortunately, I can't make it work...· To be honest, I have no RES signal on the propeller plug and no access to BOEn signal on the propeller.· When connected, my PC doesn't recognize the propeller.· Is there any way to fix that issue ?
I switched to a 40pin propeller on veroboard; two times larger, but it works.
The former µoled-96 was a dream for compact projects !
www.warrantyvoid.us/protoboardNANO.html
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Got an SD card connected? - PropDOS
Not easy to solder this wire, but now it works!
This is in fact very compact and not too expensive.
