I have seen those before. Usually all the are is the ultrasonic sensors by them selves and you have to make the them work. Where as with the Ping it already does all the hard work and is very simple to work with.
Ping is the way to go for sure.· It is an excellent sensor...reliable and durable.· The image you have is the Devantech SRF04.· The mount hardware in the photo looks like a Budget Robotics product.
The pan setup in your picture looks nice though... where'd you get the image from and do you have a link to the pan turret?
I found it here.
http://www.budgetrobotics.com/shop/?shop=1&cart=730666&cat=137
I would be nice if my Boe-Bot can tilt its head and look down. using a Ping))) Sensor from Parallax.
BWIN ON DA POWAH WIFIN U!!!
http://www.crustcrawler.com/products/s3.php?prod=8
...which means that at $20, it costs the same as the Parallax one:
www.parallax.com/Store/Robots/RoboticAccessories/tabid/145/CategoryID/51/List/0/Level/a/ProductID/248/Default.aspx?SortField=ProductName,ProductName
Funny how that works.
T-man··
