Reading a Data Sheet (Help Meh!) — Parallax Forums
RICoderRICoder Posts: 91
edited 2009-02-02 01:27 in General Discussion
I have a DS1620, and I'm trying to figure out why it works perfectly with a BS2, but when I use the Prop it behaves weirdly (and it ain't my code). In that process I have come upon some questions, and they are thus:
You can find the datasheet here: http://www.parallax.com/Portals/0/Downloads/docs/prod/compshop/DS1620 Digital Thermometer Data Sheet.pdf
In the datasheet I see this (PAGE 11)
Input Resistance RI RST to GND, DQ, CLK to VDD 1M ohm
The 1M ohm is in the MIN column. Does this mean that those pins need that much of a resistor on them to work properly? It looks to me like I ought have a resistor from RST to GRN and one from CLK to VDD (which is really CLK to the pin on the chip) and one on the DQ pin to the chip. And is 1M ohm 1 MILLION ohm? What the hell kind of resistor is that?
Next question is speed of the DS1620 chip itself. I'm starting to wonder if the fact that my prop is running at 80MHz is causing issues talking to the DS1620. So, again, we look at the datasheet. (PAGE 11)
CLK Frequency fCLK DC 1.75 MHz
Where 1.75 is in the MAX column. Does this mean it cannot deal with clk pulses coming faster than 1.75MHz?
  • LeonLeon Posts: 7,620
    edited 2009-01-31 20:42
    That value is the resistance you'd measure between /RST and Gnd. You just need to ensure that /RST is connected to the appropriate pin on the Propeller, you don't need to add a resistor.
    You should keep the clock frequency at or below that 1.75 MHz maximum level.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    edited 2009-01-31 20:54
    RICoder,
    The 1M reference on page 11 is referring to the input impedance on those pins. Generally speaking, an input to any device can be a direct connection providing that the device you are connecting to has an operating voltage that is greater than or equal to the processor voltage. i.e. 3.3V for Propeller, 5V for a BS1,BS2,SX . For an output on a device, the rule is the same for an input unless there is a chance that there could be a collision between the data being sent verses data being received... i.e. bi-directional data. In such a case a current limiting resistor, usually 1K or so, is placed in series between the processors I/O and the device being controlled.
    BTW the DS1620 has a voltage range from 2.7 to 5.5, so a 3.3V supply from the Propeller will work just fine.
    There is an object located in the OBEX for the DS1620, but it does not tell you how to connect the chip to the Propeller.
    http://obex.parallax.com/objects/search/?q=DS1620
    Here are some other links.
    http://forums.parallax.com/forums/default.aspx?f=25&m=147200
    http://forums.parallax.com/forums/default.aspx?f=15&m=147338
    Beau Schwabe
    IC Layout Engineer
  • lorayroverlorayrover Posts: 2
    edited 2009-02-02 00:56
    · Reading a data sheet are a fact of life if you want to dabble in electronics or with electrical devices.· You don't have to understand every single parameter for every device either,· sometimes you may only need to know the MAX Voltage or Current of a particular device and that will be enough, other times you may need to know a lot more.· Knowing few of basics in many cases will be all that is required and may keep you out of trouble.
    SPAM REMOVED
    Post Edited By Moderator (Aristides Alvarez (Parallax)) : 2/2/2009 1:29:15 AM GMT
  • Aristides AlvarezAristides Alvarez Posts: 499
    Spam account lorayrover locked.
    Aristides Alvarez
    Education Manager
