Prop Code Help (whacky results) — Parallax Forums
RICoderRICoder Posts: 91
edited 2009-02-02 00:32 in Propeller 1
I'm having a few problems and weird symptoms, and I don't know if its me, or if its the chip. (the setup is a prop with a DS1620 thermostat chip). I know that the chip is set up properly, because I have moved the jumpers to a BS2 and it works just fine.
I'll be running my code, and it will seem fine, giving me a temperature that looks like what it should be for the ambient temp. As I update my code and move things around doing a few different tests, the values suddenly get all whacked out, like 76 degrees F from the last time I ran, and now its 124 F, which is just crazy.
Meanwhile, I'm using the FullDuplexSerial object from the obex, and that works just fine in the main program routine. Then I try to put some debug code in to inspect the bits I'm getting from the DS1620 in a subroutine, and the output is garbled from the sub, but not in the main.
If this was C++ on a PC, I'd say it was symptomatic of me writing over memory I didn't own...but I don't know about the prop chip. Any insight would be useful.
ex:
PUB Main
  repeat
    lFTemp := GetTemperature (PIN_DQ, PIN_CLK, PIN_RST)
    DEBUG.start (31, 30, 0, 9600)
    DEBUG.str (string ("DEC (F): "))
    DEBUG.dec (lFTemp)
    DEBUG.tx (13)
    TIME.pause1ms (2000)
PUB GetTemperature (DQ, CLK, RST): lTemp | lReadTemp
  outa[noparse][[/noparse]RST]~~
  IO.shiftout (DQ, CLK, io#LsbFirst, CMD_READ_TEMP, 8)
  lReadTemp := IO.shiftin (DQ, CLK, io#LsbFirst, 9)
  DEBUG.bin (lReadTemp, 9)
  lReadTemp := lReadTemp >> 1
  lTemp := lReadTemp * (9/5) + 32
    edited 2009-01-31 08:41
    If I'm not mistaken, FullDuplexSerial uses its own cog, and buffers the data being sent/received. Calling DEBUG.start() more than once in your app is going to wreak all kinds of havoc. For example, the call inside GetTemperature won't have time to finish sending before you re-start the lib.
    Take the DEBUG.start() call out of GetTemperature completely, and move the other one outside the repeat loop - That'll probably do it.
    Jason
    edited 2009-01-31 09:50
    Hello RICoder,
    the FullDuplexSerial-objects (shortname for FullDuplexSerial FDS) runs in its own cog
    You start the cog by using the start-command
    Now if you start TWO cogs with the FDS-object and BOTH
    cogs use the same IO-Pins (31,30) the signals can get messed up
    You may ask how this can be using the commands sequential
    As the FDS-object runs in its own cog it is completly independent
    of all other cogs. Using the str-command fills in the characters
    into the sendbuffer of the FDS-object very quickly
    it needs time more to send them out at 9600 baud then to write it into the buffer
    so it might happen that cog A running FDS still sends out characters of the string
    as cog B starts to send out data too
    Just start the FullDuplexSerial-object ONE time in your main method
    After that you can use the the FDS-methods "str", "dec", "bin" etc. in any other
    method like GetTemperature or what methods ever
    Simply remove the
    in your GetTemperature-method and it should work
    and put the
    in the main-method outside of the repeat-loop
    For a more detailed analysis of what happends you have to attach your COMPLETE code
    to your posting.
    You can do this using the "archive"-function of the proptool
    open your *.Spin-file with the main-method
    click "file" in the main-menu of the proptool
    choose and click "archive... "
    choose and click "Project..."
    this will create a ZIP-file that contains ALL files that are nescessary for compiling the whole project
    best regards
    Stefan
  • RICoderRICoder Posts: 91
    edited 2009-01-31 20:37
    ok, here's the code (attached).
    Run it as is and the serial tool shows:
    BIN RAW: 000100011
    DEC RAW: 35
    BIN SFT: 000010001
    DEC SFT (C): 17
    DEC SFT (F): 49
    SUB TMP: 49
    (can't be right)
    Comment out the sub call to GetTemperature and serial tool shows:
    BIN RAW: 101101000
    DEC RAW: 360
    BIN SFT: 010110100
    DEC SFT (C): 180
    DEC SFT (F): 212
    SUB TMP: 0
    UNCOMMENT the sub call (should be same as before) and serial tool shows:
    BIN RAW: 101101000
    DEC RAW: 360
    BIN SFT: 010110100
    DEC SFT (C): 180
    DEC SFT (F): 212
    SUB TMP: 212
    What in god's name am I doing wrong?
    edited 2009-02-01 09:56
    Hello RICoder,
    first of all yyou are good at adding well formatted debugoutput to your code
    By carefully comparing your code with the DS120-democode from the obex
    I discovered a difference
    the obexdemo-code uses the constant "io#LsbPre" for reading the temperature
          tc := io.shiftin(dpin, cpin, io#LsbPre, 9)          ' read temp in 0.5° C units
    your code uses constant "io#LsbFirst"
      lTemperature := IO.shiftin (PIN_DQ, PIN_CLK, io#LsbFirst, 9)
    If you take a close look at this codeline
    io#LsbPre, 9 reads in NINE bits
    io#LsbFirst, 8 reads in EIGHT bits
    I have no DS1620 laying around here that I could do a test on my own.
    But there is a good chance that this is the bug.
    Before I found this I was thinking about the following questions
    Did YOU test the temperature-reading in a REPEAT-loop ?
    The democode you attached reads in the temperature ONE time and then only
    outputting the results is repeated
    As you get different values it might has to do with uncomplete reading data
    a.) not enough bits read
    b.) wrong bitorder MSBFirst instead of LSBfirst
    etc.
    By repeating the reading, you test if you are reading the bits the right way
    So what could be learned IN GENERAL from this case ?
    1.) asking the experts from the forum is a good idea
    2.) to get satisfying answers give satisfying info about what YOU want to do
    3.) start reading the Datasheet of the DS1620 carefully while waiting for the forum to answer
    The datasheet says
    "Writing to the E2 typically requires 10 ms at room temperature. After issuing a write command no
    further writes should be requested for at least 10 ms."
    you are waiting only 5msec in your code
    for testing I would wait for 20msec to make REALLY sure that this detail works properly
    best regards
    Stefan
    edited 2009-02-01 17:23
    @Stefan, thanks, those are some really good comments on what I'm doing (and even how I'm posting). I've been reading and thinking a lot, so I'll go do some experiments like you were saying and report back.
    edited 2009-02-01 19:06
    ...As a programmer I should be used to it, but there are just so many variable.
    - Is it the Prop chip since I can't be 100% sure it is working
    - Is it the DS1620 chip, since I am not sure if I may have fragged it with my code
    - Is it the C code for the chip, since I just started coding for it
    ...oh...maybe its just that my calculation for Centigrade to Fahrenheit is wrong! d'oh!
    (it was also the stuff stefan said...so thanks)
    FYI: My code runs flawlessly now, but the DS1620 object is not so accurate. It may still be that my code is wrong, but giving me the right results. If I figure it out, I'll post.
    edited 2009-02-02 00:14
    RICoder,
    "My code runs flawlessly now, but the DS1620 object is not so accurate"
    You should consider looking at the DS1620 in high resolution mode.
    In Standard mode, 0.5 Deg C resolution translates to 0.9 Deg F resolution. In High-resolution mode you get 0.0625 Deg C resolution that translates to 0.1125 Deg F resolution.
    Beau Schwabe
    IC Layout Engineer
    Allow me to retract and restate. With my code, the chip works fine, and I get proper readings. With the DS1620 code, I get unusual, sometimes completely flawed readings (like 148d F). I might have screwed a little with the code in the DS1620 object, and will re-download and try again.
