need a +-10V DAC output from the propeller.
I'm looking for the easiest way to get a +- 10v DAC output from a propeller protoboard. The protoboard is powered by a 12v regulated power bus from the rest of the system. My current idea is filter this 12v, invert it using a switch mode inverter (capacitive or inductive), generate my DAC signal with a counter and RC filter, then run an op-amp off the +12v and -12v lines to boost the counter's output to +-10v. (assume the DAC needs to drive a ~10kohm load)
I vaguely remember a forum thread about using some propeller pins to form a small switching power supply, can't find it for the life of me.
Marty
Lunch cures all problems! have you had lunch?
Marty
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I did a bit more searching and found some stuff. It looks like a Microchip TC962CPA charge pump IC will generate a nice -12v rail for me. I'll use extra large capacitors to minimize ripple. Also the Linear Tech LT1498CN8#PBF rail to rail op-amp looks like it will easily do what I need.
@Dr_Acula: I looked up the CA3140 op-amp. It doesn't look like it's a rail-to-rail op-amp. It IS a lot cheaper than the op-amp I found, know any other good op-amps too look at?
Marty
Lawson
