MC24LC256 Not functioning at all — Parallax Forums
GibithGibith Posts: 18
edited 2009-01-31 07:59 in General Discussion
I'm trying to simply store bytes on a MC24LC256 EEPROM. I tried using the the test and demo programs that comes with the Appnote associated with this EEPROM, and none of them seemed to work. When I run MC24LC256Demo I get the introduction text but nothing after that. It's the same for the MC24LC256Test program, I get the introduction text but nothing after that. I'm at a complete loss. I'm going to check my wiring again as well.
  • GibithGibith Posts: 18
    edited 2009-01-30 17:54
    I think my problem is that I'm not using a pull up resistor on the SDA. How do I wire that? I've got my javelin on a board of education.
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2009-01-30 19:23
    You·need pullup resistors on both SDA and SCL line.
    Connect one side of the resistor to the pin and the other side
    of the resistor to the 5V supply.
    Also make sure the javelin ground (aka GND or VSS) is connected
    to the eeprom ground.
    regards peter
    edited 2009-01-30 21:54
    That sorta worked. It now finishes the test but of the two eeproms that I have tried, both of them failed the tests. However, since I didn't have any 2k Ohm resistors that the data sheets suggested I used 2.2k Ohm resistors. I figured the extra 200 Ohms wouldn't matter. But seeing as how it doesn't work maybe it does matter.
    What program do you use to test?
    Depending on eeprom capacity, there must
    be 1 or 2 address bytes send. Your eeprom
    version requires 2 address bytes. If the test program
    only sends 1 address byte (by only testing the
    first 256 addresses) then the test would fail.
    In that case you must insert a writebyte command
    sending the highbyte of a 16bits address.
    regards peter
