Blown Serial to USB converter
I am working with a BS2 on a prototyping board which is powered by a 6.5 volt DC supply. When I connect a PC to the serial to USB converter, the converter blows. This does not happen when a battery is used. Do I have a grounding issue??
Any help would be appreciated.
Dave
Dave Andreae
Parallax Tech Support·
I will field a guess that you 1.4v voltage drop has to do with the Ron of 25~35 and ohms law.....
the only mention of a 1.2 voltage drop is on the led side of things
link
Post Edited (lincoln) : 2/6/2009 9:06:47 PM GMT
