Outputing Data to PC — Parallax Forums
bbnqondbbnqond Posts: 16
edited 2009-01-31 11:18 in BASIC Stamp
Hello everyone,
I am currently working on a project which requires data logging.
I would like to use I2C device (24LC16B) to log the data. However, I would also like to output the data to PC. I wonder if it is possible for me to output data stored into I2C device to PC?
bbnqond
  • sylvie369sylvie369 Posts: 1,622
    edited 2009-01-30 11:30
    Sure. Just read the data from the device into BS2 memory, then send it out the serial port to the PC. The quick-and-dirty method to read it on the PC is to capture it to a file using a terminal program. Alternatively, you could set up a file to capture it to Excel using PLX-DAQ:
    http://www.parallax.com/tabid/441/Default.aspx
  • Craig EidCraig Eid Posts: 106
    edited 2009-01-31 05:14
    Using Hyperterminal as your terminal program can cause some grief. I have successfully used Jan Axelson's
    Com Port Terminal -·http://www.lvr.com/serport.htm#pccode·- and it is a good starting point. Microsoft has a more sophisticated terminal program available·in the Samples folder in Visual Basic 6.0.
    Craig
    I use one called "Realterm". It seems to be able to do just about anything:
    realterm.sourceforge.net/
