board of education question
hey, my board of education is having problems. Randomly, pin 1, 7, 10 and 14 have been acting weird.
When I power up my boe and connect a led to any of those pins I mentioned, it comes on, even if the pin is not programmed. I am able to program it to flash and all, but
it stays on even when its not programmed. If i set it low, it blinks every 2 secs unless that low is betwen a do and loop.
When I use any of those pins to activate a transister-relay circuit, RCTIME or button circuit, it does not work. Only for the LCD and leds--sorta.
Any Ideas? All the other pins work fine. I tried resetting the boe.
Chris.
Chris.
Dave
Dave Andreae
I forgot to mention that this all happend shortlly after a tiny peiece of wire broke off inside pin 11. Could that be the problem? If i was able to remove it
with something tiny would it fix it? or is there something else that could be wrong--it does not seem like the pin is dead since its responding to the boe and program.
Dave
Dave Andreae
Parallax Tech Support·
