RE: Graphics Overlay
This subject has been talked about before. I built the overlay graphics card and then used the existing Flight Drone code. The graphics overlay actually worked great. The project needs to read a tilt sensor (at 10Hz) and Parallax GPS Sensor (at 1 Hz) and then display the data with dials over a camera image. I configure a cog for the each sensor (I also give the cog the address of the global variable) to extract the sensor data, and then use the main cog to display the data on the TV output. The problem is data displayed on the screen is very jump. I suspect the main cog is reading the global variables while the other cogs are writing to them. If the read sensor functions are placed in the main cog code, then the display is very stable but the update rate will be 1Hz.
Paul Baker
