hitec — Parallax Forums
hitec
wmngummiewmngummie Posts: 2
edited 2009-01-29 18:06 in Robotics
has anyone ever controlled the boe bot with a hitec remote control?
  • ZootZoot Posts: 2,227
    You mean with a radio transmitter? Yes it's been done many times. The radio receiver is tied to Stamp input pins; one for each channel. Then PULSIN is used to measure the pulses coming from the transmitter/receiver combo. These will correspond to standard RC values (1ms-1.5ms neutral-2ms, or .5ms-1.5ms-2.5ms if extended range).
    What you do with the values from the transmitter is up to you.
    I suggest putting a 220ohm or so resistor between the receiver pins and the Stamp pins so that you don't cook a Stamp pin if you accidentally make the pin an output.
