BOE-BOT 10 inch Round Platform. I live in Australia.
The idea of using Acrylic Plastic failed because it chips easily and it is heavy What else Could I use? I don't want to use Plywood because of the weight.
Is there any no conductive material to make a strong round Platform?
And does anyone have any designs on contact touch sensors that fit on the edge of the platform?
Any Ideas?
BWIN ON DA POWAH WIFIN U!!!
Post Edited (Ezsynn) : 1/31/2009 5:06:41 AM GMT
Any Ideas?
The weight was too high for the servos I presume?
If that's the case, you can always use different servos or motors.
Also at craft stores they have craft plywood. Small pieces in diffent thicknesses. I think it would work well too.
Whit+
The book Robot Programmer's Bonanza has a modified Boe-Bot on the cover with a round base.· The base is ringed by an ingenious DIY contact sensor.
This book is about the free RobotBASIC simulation software, which is great fun to play with, and has an entire chapter on porting your simulator-developed sensor algorithms to a real Boe-Bot with Parallax sensors.· The directions for making the contact sensor bumper-skirt are in that chapter.
-Stephanie Lindsay
Editor, Parallax ZInc.
http://www.budgetrobotics.com/shop/?cart=730188&cat=5&
PG
Ezsynn, a little FYI for you, when cutting Acrylic you must use a 6T blade, This will help so you don't chip or crack the plastic even Lexan you would use this blade as well.
If weight is your concern, use very thin acrylic and brace it off with aluminum 90' corner rods or use what the guys posted above.
Jax
If a robot has a screw then it must be romoved and hacked into..
Post Edited (GWJax) : 1/30/2009 1:21:08 AM GMT
Yo, I already know that cause I've got the book. I was going to make it until I saw the budget and the book had no instructions on how to build it so, I might as well design my own.
