Rohs requirements & FCC
I am attempting to sell an electronic item of mine.
What are the implications if any of selling an item that is not rohs compliant in the usa? Or is a disclaimer needed?
Post Edited (Erik Friesen) : 1/29/2009 2:57:04 AM GMT
There may also be other exemptions for older equipment but that is a gray area.
Robert
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Phil Pilgrim (PhiPi)) : 1/28/2009 11:19:10 PM GMT
Per leon, I is EMC an issue at all?
It'll have to satisfy the FCC requirements for the USA, as well as UL.
Leon
Gadget Gangster - Share your Electronic Projects - Sign up as a Designer and get a free 4-pack of Project Boards!
1) Read what you can about FCC part 15. IE: Wikipedia, net searches for "FCC Part 15 certification", and of course http://www.fcc.gov/oet/info/rules/
2) Contact a few authorized certification labs and request more information about their process and fees.
CCL in Salt Lake does FCC part 15 and 68 certs. www.cclab.com
Agile www.agiletestgroup.com
Linx technologies recommends www.celectronics.com
3) Review your product's design again and again. Do not cut corners where RF emissions are involved.
4) Have your product reviewed during a quote request by a testing lab. In some cases, they will assist you in being fully prepared to start before the fees begin.
5) Be prepared to make design changes quickly if issues are found during testing.
I have been involved with a about a dozen FCC Part 15 certs and most of them went smoothly. The few with issues required minor fab changes, EMI shielding changes, or a wall wart change. (Yes, one failed because the wall wart was a piece of junk, go back to #3)
Timing ranges from 2-5 months and can cost between $4k and $10K depending on complexity of your design and the cert lab's fee structure.
good luck!
~~ dRu ~~
Post Edited (dRudRudRu) : 1/29/2009 8:39:25 AM GMT
Here is what I am doing.
estimationcreation.com/index.html
Post Edited (Erik Friesen) : 1/29/2009 12:43:22 PM GMT
~~ dRu ~~
Leon
One thing I had decided early on was to drop the battery charging. That can add an entire dimension to the testing. The equipment they use can pick up harmonics and noise from anything. 30 DBuv doesn't leave a lot of room for something funny going on. The tester told me of one product that failed because of the wall wart.
I would like to be left alone in the lab for a few hours to play with the equipment. ha ha. Each receiver (there are two of them in the 10m range) can test from 30 mhz to 2 ghz and cost $100,000.
Leon
