Blinded by ASM
This is perplexing me. I'm modifying the MCP3208 object to do a few extra things. Being very new to assembly, I've run into a lot of problems, but this one I just cant seem to figure out.
The top spin object is calling these methods from my assembly/spin sub object:
This is the most pertinent code in the sub-object:
And the spin code from the modified MCP3208 object:
Finally, here's the output to the serial term:
The floating point value after the '|' should be 2025, since it was converted to FP from the integer in channel_0, but instead it looks as if it is it is being converted from the integer channel_1. Since I'm advancing the pointer after the loop, shouldn't both the first long written to HUB memory and the floating point value (which is directly reverenced to channel_0), be the same?
PUB sendReportPacket uarts.dec(DEBUG_PORT, imu.in(0)) uarts.tx(DEBUG_PORT, ",") uarts.dec(DEBUG_PORT, imu.in(1)) uarts.tx(DEBUG_PORT, ",") uarts.dec(DEBUG_PORT, imu.in(2)) uarts.tx(DEBUG_PORT, ",") uarts.dec(DEBUG_PORT, imu.in(3)) uarts.tx(DEBUG_PORT, ",") uarts.dec(DEBUG_PORT, imu.in(4)) uarts.tx(DEBUG_PORT, ",") uarts.dec(DEBUG_PORT, imu.in(5)) uarts.tx(DEBUG_PORT, ",") uarts.dec(DEBUG_PORT, imu.in(6)) uarts.tx(DEBUG_PORT, ",") uarts.dec(DEBUG_PORT, imu.in(7)) uarts.tx(DEBUG_PORT, "|") uarts.str(DEBUG_PORT, floatString.floatToString(imu.in(8))) uarts.tx(DEBUG_PORT, CR)
_imu_update mov kt1,par add kt1,#28 mov kt2,#channel_0 mov kt3,#8 mov kt4,#offset_0 :aloop movs :sub_offset,kt4 :sub_offset subs kt2,0 movd :read_from,kt2 :read_from wrlong 0,kt1 add kt2,#1 add kt1,#4 add kt4,#1 djnz kt3,#:aloop mov fnumA,channel_0 call #_ffloat wrlong fnumA,kt1 _imu_update_ret ret offset_0 long 0 offset_1 long 0 offset_2 long 0 offset_3 long 0 offset_4 long 0 offset_5 long 0 offset_6 long 0 offset_7 long 0 channel_0 res 1 channel_1 res 1 channel_2 res 1 channel_3 res 1 channel_4 res 1 channel_5 res 1 channel_6 res 1 channel_7 res 1
VAR long cog long ins '7 contiguous longs (8 words + 1 long + 2 longs) long count long dacx, dacy long imuData[noparse][[/noparse]16] PUB in(channel) : sample '' Read the current sample from an ADC channel (0..7) return imuData.long[noparse][[/noparse]channel]
2025,1878,1516,2054,2012,1635,4095,13|1877
Post Edited (Mark Swann) : 1/28/2009 9:42:30 PM GMT
I can't find anything in the documentation suggesting the extra NOP. Is it a bug?
Cheers!
Paul is right. Go look in deSilva's PASM tutorials.
http://forums.parallax.com/showthread.php?p=668559
Mark
Post Edited (Mark Swann) : 1/28/2009 10:03:58 PM GMT
