PASM need some help, ctra x 3
Hi. I want to use 3 input's for frequency counting ( P18,19,20 ),around· 100 KHz.
I tried to modify the code from AN001 but i cannot get the 2'nd and 3'd counter to work.
I just start to try to understand PASM, so probably my problem is in tha't part...
Okay, i'll try to insert "my" code here.
Thank's, Olov, Sweden...
''Demonstration of the counter used as a frequency counter
' 20 mm = Khz
' 40 mm =
' P11 Down 3
' P12 Up 3
' P13 D2
' P14 U2
' P15 D1
' P16 U1
' P18 Sensor 1
' P19 S2
' P20 S3
' P21 Kollision 1
' P22 K2
' P23 K3
' P24 RS485 TXDE
' P25 TX
' P26 RX
CON
Vald_Hojd = 160000
Hysteres = 2000
_clkmode = xtal1 + pll16x
_XinFREQ = 5_000_000
OBJ
debug : "FullDuplexSerial"
VAR
long Akt_Hojd,Akt_Hojd2,Akt_Hojd3,Fq1,Fq2,Fq3
long CogStack1[noparse][[/noparse] 20]
PUB Go
Dira[noparse][[/noparse]11..16]~~
debug.start(31, 30, 0, 9600)
cognew(@entry1, @fq1) 'New cog for the 1'st freq.counter
cognew(@entry2, @fq2) ' 2'nd fq-counter
cognew(@entry3, @fq3) ' 3'd fq-counter
cognew(M1,@CogStack1) ' Routine for serial output of values
repeat
Akt_Hojd := fq1
Akt_Hojd2 := fq2
Akt_Hojd3 := fq3
If AKt_Hojd > Vald_Hojd + Hysteres ' För nära plåten
OutA[noparse][[/noparse]16] := 0
OutA[noparse][[/noparse]15] := 1
elseif AKt_Hojd < Vald_Hojd - Hysteres ' För långt ifrån plåten
OutA[noparse][[/noparse]16] := 1
OutA[noparse][[/noparse]15] := 0
else
PUB M1
repeat
waitcnt(ClkFreq * 1 + cnt) 'wait 1 seconds then set MyVar to value 1
debug.str(string("Fq1 = ")) ' Send to the PC
debug.dec(Akt_Hojd)
debug.str(string("Fq2 = "))
debug.dec(Akt_Hojd2)
debug.str(string("Fq3 = "))
debug.dec(Akt_Hojd3)
debug.Tx(13)
DAT
org
entry1 mov ctra, ctra_1 'establish mode and start counter
mov frqa, #1 'increment for each edge seen
mov cnt_1, cnt 'setup time delay
add cnt_1, cntadd1
:loop1 waitcnt cnt_1, cntadd1 'wait for next sample
mov new1, phsa 'record new count
mov temp1, new1 'make second copy
sub new1, old1 'get delta
mov old1, temp1 'set next delta's base
wrlong new1, par
jmp #:loop1
entry2 mov ctra, ctra_2 'establish mode and start counter
mov cnt_2, cnt 'setup time delay
add cnt_2, cntadd2
:loop2 waitcnt cnt_2, cntadd2 'wait for next sample
mov new2, phsa 'record new count
mov temp2, new2 'make second copy
sub new2, old2 'get delta
mov old2, temp2 'set next delta's base
wrlong new2, par
jmp #:loop2
entry3 mov ctra, ctra_3 'establish mode and start counter
mov cnt_3, cnt 'setup time delay
add cnt_3, cntadd3
:loop3 waitcnt cnt_3, cntadd3 'wait for next sample
mov new3, phsa 'record new count
mov temp3, new3 'make second copy
sub new3, old3 'get delta
mov old3, temp3 'set next delta's base
wrlong new3, par
jmp #:loop3
fit 496
ctra_1 long %01010 << 26 + 18 'mode + APIN
cntadd1 long 80_000_000 'wait 0,1 second, answer in Hz/10
ctra_2 long %01010 << 26 + 19 'mode + APIN
cntadd2 long 80_000_000 'wait 0,1 second, answer in Hz/10
ctra_3 long %01010 << 26 + 20 'mode + APIN
cntadd3 long 80_000_000 'wait 0,1 second, answer in Hz/10
cnt_1 res 1
new1 res 1
old1 res 1
temp1 res 1
cnt_2 res 1
new2 res 1
old2 res 1
temp2 res 1
cnt_3 res 1
new3 res 1
old3 res 1
temp3 res 1
eg
' set the PASM variables
ctra_1 := %01010<<26 + 18
dest_1 := @spin_variable_1
cognew( @entry, doesn matter )
ctra_1 := %01010<<26 + 19
dest_1 := @spin_variable_2
cognew( @entry, doesnt matter )
ctra_1 := %01010<<26 + 20
dest_1 := @spin_variable_3
You may have to do some more book-keeping, depending on how you rewrite the PASM code.
Cheers!
