Idea for Improving Propeller Tool
I was wondering if anybody else wishes that there was a spell check for the Comments when writing Code. I know that I am a horrible speller and have wanted this several times
So is this a bad Idea. Or maybe a Good Idea that would just be to hard to make work.
how about copy & paste it to any other texteditor with spellchecking ?
maybe this could be some way automated using PRE-Spin
best regards
Stefan
Spelling isn't difficult.· Many 7-year-olds can do it.· Once you learn each word, you will know it always.· Unlike electronics, medicine, law, history, politics, or any other field in which people study, spelling doesn't change.· You won't have to keep relearning it.· Each word will stay the same your whole life long.
So how do you learn to spell?· Reading is the most enjoyable way, though there are others.· Spend an hour a day reading writers who write well.· Fiction, or non-fiction, or magazines (but not Nuts & Volts, which has generally defective English).· It's much more fun than watching TV, and it doesn't annoy others in the house.
Read Scientific American·or the daily newspaper (most have good spelling, though perhaps poor English -- AP has good spelling and bad writing) or John Steinbeck or Mark Twain or the Harry Potter series or Naval History or the Encyclopaedia Britannica -- there's something for everyone.· That will improve your language skills generally, which will enhance your whole life -- although your original post gives ample evidence that you already express yourself much more clearly than most people can.· That's a plus.
If bad spelling were a drug addiction, then spell checkers would be enablers.· Using enablers will only prolong the problem, whether it's inadequate spelling or heroin.
Always attack the problem, not just the symptom.
· -- Carl, nn5i@arrl.net
There are a few things I would like to see that would make things much easier.
1) ability to set default values for subroutines. I recommend the PHP method of just placing =value after variable name. compiler could then add default value in when omitted in calling function. this would help when altering code to add new functions to subroutines. old calls would still work.
2) Keep track of already declaired variables and when you start typing in a variable it will show you those that would fit. Much like Komodo Edit does for me in my PHP programing.
3) Local variables to a subroutine. Compiler could assign fixed address still would just make larger programs easier since you would not need to worry about duplicating variable names
Cutting and pasting in a text editor works sometimes. I like the idea of a spell checker that looks at only the comments.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto for SunSPOT, BitScope
www.tdswieter.com
