NiMh or Lithium Polymer ?
which one do you choose to supply your boe bot? NiMh or Lithium Polymer ? Or does anyone has another option ? Pls, i need recommendation here! I have 3 servos, 1 hm55, 2 ping, 1 lcd, and some IR.
Post Edited By Moderator (Joshua Donelson (Parallax)) : 10/23/2009 4:26:54 AM GMT
Putting a subject on your posts will help those who can help respond. The NiMh work well, but you need an extra AA. See the BOE-Boost for an easy way to do this.
Whit+
http://www.parallax.com/Store/Robots/RoboticAccessories/tabid/145/CategoryID/22/List/0/SortField/0/Level/a/ProductID/455/Default.aspx
Dave
Dave Andreae
Parallax Tech Support·
Bean (Hitt Consulting)·on the forums also sells a 5 cell AA battery holder on his website. It fits nicely in the BOE-Bot chassis. You can find it here.
Whit+
Post Edited (Whit) : 1/29/2009 12:21:11 AM GMT
As such, the cost was about $340, counting the charger. liPoly would have almost been double that. the 13K battery weighs about the same as a 7ah gel cell but will run almost twice as long.
Dave Evartt
People don't hate computers, they just hate lousy programmers.
http://wehali.com
I'll have to disagree with that. Running time will depend upon the capacity (mah) of the battery, not the chemistry. LiPo's will have a higher energy density than NiMH so for a given physical size the LiPo will have a higher capacity.
Also, there are LiPo's that are rated for 40c continuous discharge. I don't know of any NiMH that can support that high of a current drain.
My favorite battery for the Boe-Bot is a six cell RC pack like SRLM describes except I remove one cell to make it a 6 volt pack. Very few servos are intended to be run at more than 6 volts.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
For what you are doing, weight really isn't an issue. I'd use a NiMh pack no question. LiPo packs require too much care in dealing with them. Shorts often fry the pack, you have to be concerned with cell balancing so to not over-discharge one cell, cost more....Naaaaah. For energy density, LiPo's are the trick, but NiMh are pretty forgiving to abuse. You can get some pretty small 2500mA NiMh packs if you need that much. 1500mA packs are a dime a dozen, and quite small!
"puff"...... Smile, there went another one.
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_2115821_-1
John Abshier
I have used TONs of the Duracell 2650mAH AA cells for robots Ham radio stuff and the like . not a single failure yet .
Peter KG6LSE
"Carpe Ducktum" "seize the tape!!"
peterthethinker.com/tesla/Venom/Venom.html
Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
LOL
