First time Voltage Regulator questions
I'm working on a project that uses a voltage regulator for the first time so I have a couple quick questions...
My voltage regulator has a 1amp limit. This is the same as on the BOE so I'm assuming that's plenty of juice... if I were to heat sink it, would it be able
to go a bit higher?
How do you know when to use a heat sink and when its not needed?
The caps used in the circuit on the input and output... the ratings stated are 0.33uf and 0.1uf... would using a much higher rating (10uf) cause any problems?
Another cap question... I'm assuming the schematic calls for ceramic caps... would using electrolytics cause any problems?
I'm pretty sure I know most of this but I don't want to take any chances... any feedback would be great.
Thanks!
to go a bit higher?
Thanks!
Most single chip voltage regulators self-limit the amount of current they pass.
The regulator's spec sheet will list the maximum free air power dissipation into a stated amibient air temperature. Going beyond that would require a heat sink on the device.
The regulator's spec sheet will have info on suggested input/output decoupling caps. Going below those values may introduce too much ripple and going over them may cause oscillation issues.
One of the top rules in electronics is, never assume anything. Educated guesses are much better. I'd stick with whatever the spec sheet states.
DJ
Another thing is that a given size ceramic cap typically has much quicker response than a larger cap (ESR). You might get away with a 1uf but I doubt a 10uf will work well in a critical application
Which voltage regulator are you using? The caps issue is entirely dependent on that. Some regulators allow the output capacitance to increase beyond the minimum specs without limit. Others impose both upper and lower ESR limits on the caps, as well as capacitance limits. This will determine what type of cap you have to use. It goes on and on. So give us a part number, and we can provide more incisive advice.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
It's a 7805a voltage regulator from radioshack... I had a hard time finding a datasheet for it but I finally found the
attached... although it seems slightly incomplete.
I may have missed it... but I also can't figure out the voltage drop from the datasheet.
I'm using a 6v 2.8AH lead acid battery to feed the 7805a... I'll be drawing 5v through the regulator for some
electronics and 6v straight from the battery for 4 motors.
I connected it up with two 10uf electrolytics and ran an LED and a motor for about 2 hours with no heating what
so ever on the regulator... this is before I read Leon's post.
Are the caps for smoothing the power so sensitive electronics like a microprocessor or other ICs don't fry or
is there some other reason?
I don't get why this regulator requires ceramics of a specific size and the BOE has a 5v regulator with two 1000uf
caps connected.
Maybe I should just connect the battery to a BOE and use it to regulate the power... I didn't do this originally
because I read that its better not to have a microprocessor on the same power source as a motor (or in this case,
4 motors).
Any opinions or advice is absolutely welcome.
Edit: I'm using the second example in the datasheet, except with the 10uf caps.
For a 5V output (7805), I'd suggest at least 8V for an input voltage.
Post Edited (Mike Green) : 1/28/2009 12:42:06 AM GMT
I'm assuming that this is a case where an O-scope would be very useful.
I also have a couple regulators from a surplus store's random packages... anyone know much about a LX8386-05ip? I know its a 5 volt regulator and I've yet to look at the datasheet (was curious
if you guys had any experience with it)
Same deal with a PLX8386-05ip. I'm assuming its pretty much the same as the other.
I've never used it but here's a link for a datasheet
http://www.datasheetcatalog.org/datasheet/microsemi/LX8386.pdf
This post is a work of art. Variations in spelling and grammar are intentional, artistic endeavors that add value to all of mankind.
The voltage differential is usually the cause when there is overheating problems.
8 in - 5 out x 1 amp = 3 watts
12 in - 5 out x 1 amp = 7 watts
18 in - 5 out x 1 amp = 13 watts
Note that in each case the current is the same.
When thinking of how much heat this represents, consider holding the equivalent size light bulb in your hand while it's on.
Here is some good basic info on regulators.
www.national.com/appinfo/power/files/f4.pdf
- Rick
Leon
