Propeller Boe Bot
Peter J. Fischel
I have been tempting to make my Boe-Bot more advanced by using the propeller chip.
The 8 cogs make it sound as though it is plenty of power to drive the sensors and give me room to advance my robot.
I purchased the Propeller Proto Board USB mainly because it has the same mounting holes as the basic stamp that was on my boe-bot.
What is concerning me is,· the servos. To me the Basic Stamp is really tough and I can plug the servos directly to the device no problem. However, is there anything I need to be concerned with when connecting the servos to the propeller board?· I know it has the plugs for it and I ordered the pins for it.
Please keep in mind, i have 3 servos at the moment to connect to it. 2 Drive Servos and one to rotate PING about. Ping will be another story to connect I suppose.
Do any of you mind giving me some tips?
Fly_Mario
Fly_Mario
I will be trying these solution this weekend, as I ran out of time last weekend. Silly work, family and church keeping me away from the stuff that really matters (j/k).
http://www.parallax.com/Store/Microcontrollers/PropellerDevelopmentBoards/tabid/514/CategoryID/73/List/0/Level/a/ProductID/509/Default.aspx?SortField=ProductName%2cProductName
There is a hefty capacator on the servo connectors.
I am beginning to think this board should handle my servos just fine.· Anyone else familiar with that board?
Seems to me if we have a brownout issue, we could probably put NiCads in.· Not sure the board could handle that current though.
I am heavily into RC Helicopters, I drive·5 servos (the same as what boe bot has) a Gyro, and receiver on 6 volts.
Trust me, servos are not that picky.
To test, I hooked an LED to P3 and toggle it on and off at the start of the program and leave it off while the program runs.
When servos aren't present, the program toggles and remains off.
Hook up the servos, light toggles, the servo starts, then servo stops and LED toggles again as it restarts the program.
with power glitches.·It's an upside down boebot chassis with a few erector set parts you can see in my avatar.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ D Rat
Dave Ratcliff· N6YEE
Also, does the input on the servo need any extra part such as a resister between the prop output and the servo or is it fine?
again, thanks!
I also used a PCA9554 I2C I/O Expander to handle the HM55B compass so I could have an SD card and TV output and keep the VGA output and keyboard and mouse connections on the Protoboard. If you're willing to give up the TV output or VGA output, you don't need the PCA9554.
Time to do like Mike suggests and mount NiMH batteries.
