How to escape multi levels of IF statements?
Repeat if routineA if routineB if ReadKeyPadA > 0 spk.beep(19, 3000, 50) if PasswordCheck == true if doorpos == closed '<<<<<<<<<<< MaxSpeed := MaxSpeedOpen newpos := oPos doorpos := open spk.beep(19, 2500, 50) repeat while ReadKeyPadA > 0 'stay here until button released waitcnt(20_000_000 + cnt) if doorpos == open '<<<<<<<<<<< MaxSpeed := MaxSpeedClose newpos := cPos doorpos := closed spk.beep(19, 2500, 200) repeat while ReadKeyPadA > 0 'stay here until button released waitcnt(20_000_000 + cnt)
In the code above, if doorpos = closed, then when it gets to the next 'if doorpos = open', then the whole block cancels itself out, as the next if section resets the parameters back where they were. The solution I can use is to read the device twice like below:
Repeat if ReadKeyPadA > 0 spk.beep(19, 3000, 50) if PasswordCheck == true if doorpos == closed '<<<<<<<<<<< MaxSpeed := MaxSpeedOpen newpos := oPos doorpos := open spk.beep(19, 2500, 50) repeat while ReadKeyPadA > 0 'stay here until button released waitcnt(20_000_000 + cnt) if ReadKeyPadA > 0 spk.beep(19, 3000, 50) if PasswordCheck == true if doorpos == open '<<<<<<<<<<< MaxSpeed := MaxSpeedClose newpos := cPos doorpos := closed spk.beep(19, 2500, 200) repeat while ReadKeyPadA > 0 'stay here until button released waitcnt(20_000_000 + cnt)
But this wastes time and has other implications, but it does work to a degree.
Can anyone suggest a method to back out of the entire if ReadKeyPadA > 0 section if the first section is TRUE, avoiding it canceling itself in the subsequent section?
In the first if doorpos == closed, if it IS closed then the line below it makes it become doorpos := open, then when it gets to the next if doorpos == open, it puts the variable back where it was, canceling the whole thing out.
Maybe I am missing your point?
Post Edited (Phil Pilgrim (PhiPi)) : 1/27/2009 9:22:33 PM GMT
I am sure there must be a more complex way to accomplish this? [noparse]:)[/noparse]
Thanks!
