buyer/builder question
This is more of a buyers question. I wanted to know is there any set up that would be compact (70mmX 40mm) and contain either a USB setup with power running from the USB or a USB and AC adapter setup. That also includes Basic stamp 2 pinholes because I already own a basic stamp2 and has a bread board on it to do sensor set up on it. The last one does exactly have to be in it but would be better. I was wondering if you had something like this or if i could get it specially made or if there were parts that I could buy and make it my self.
Thank you
Thank you
It only has 8 I/O ports though and I'm not sure if it draws power from the USB connection or not... I think it does though.
If your fairly experienced at electronics, you can make your own board and hack a Parallax USB to serial adapter (remove the plug, wire it directly, tap into the +5v from the USB connection)
and run a BS2 with that... but you'd have to be darned careful.
