Communicate Using Your HYDRA Board - New HYDRA EtherX Card
The Hydra EtherX (#27933) is an Ethernet card designed to interface to the Hydra system via the Expansion port. It is built around Wiznet's W5100 hardwired TCP/IP Ethernet chip and interfaces to the Hydra using SPI.
The Hydra EtherX card comes with a complete eBook (in PDF form) describing how the sample EtherX card driver works from the ground up. The manual covers SPI (serial peripheral interface), Ethernet, and Internet protocols (IP, TCP, UDP). Knowing this, you will be able to write your own drivers for the W5100 or expand on the sample driver already written. The driver includes an easy to use API with source code, examples, tutorials, and detailed explanations. Use the EtherX card to turn the Hydra into a web server, access a file server, or play games over the internet.
For more information click on the graphic above or visit: http://www.parallax.com/tabid/143/ProductID/540/List/1/Default.aspx
Lauren Davis
Marketing Manager
916-624-8333
ldavis@parallax.com
Post Edited (Lauren Davis (Parallax)) : 1/27/2009 4:03:04 PM GMT
Lauren Davis
Marketing Manager
916-624-8333
ldavis@parallax.com
