Paul_USBDrive Memory Stick Datalogger / baudrate
I'm playing with "Paul_USBDrive.spin" and "Paul_USBDemo.spin" program.
It uses serial uart 9600 baudrate,·it works good.
I have tried to speed up the baudrate with 19200 and 115200, with no luck
Is there anyone who did·this ?
Rob.
Rob.
not much info provided from you yet
so I have to ask the obvoius
did you read the VDAPFirmwareSpec(.pdf) ?
which tells how to change the baudrate
best regards
Stefan
Yes·i know the tabel, in·the driver "Paul_USBdrive.spin"·is a PUB methode·to set the baudrate.·I have done the following steps:
1) set the uart to 9600 baud for default communication to the datalogger
2)·send the three byte $9C $80 $00 (LSB first) via PUB setBaudRate(divisor) (see tabel Vinculum)
3) restart the uart with 19200 baudrate
this did not work.
rob
Jeff T.
that's the trick,·i add in·the main of "Paul_USBDemo.spin" after the·standard uart setting (9600 baudrate) the following:
USB.setBaudRate($00809C) 'for baudrate 19200·or $00001A for 115200 baud
USB.Restart(txUSB,rxUSB,19200)·'or·115200·
waitcnt(clkfreq / 10 + cnt) 'wait 100 msec
In·"Paul_USBdrive.spin"·i·add an extra PUB·to restart the uart at 19200 baudrate
PUB Restart(tx_USB,rx_USB,baudrate) | okay
· okay := USB.start(rx_USB, tx_USB, 0, baudrate)
It al works·now also at 115200 baudrate!
thanks.
Rob.
