USB to Serial NPN transistor — Parallax Forums
EnriqueEnrique Posts: 90
edited 2009-01-26 02:49 in Propeller 1
On the USB to serial converter an NPN transistor is used to drive the RESn line to a low state but nowhere does it say what transistor is it. Does anyone know?
Enrique
  • LeonLeon Posts: 7,620
    edited 2009-01-25 17:31
    Almost any general-purpose NPN should do, like a 2N3904.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • EnriqueEnrique Posts: 90
    edited 2009-01-25 17:54
    Thanks again
  • b.p.m.b.p.m. Posts: 59
    edited 2009-01-25 19:43
    query: what USB to serial converter?!?
    is there a circuit out that uses discrete components to convert USB to serial and where can
    i find the schematic for it?
    blake
    "Can't sleep, clown will eat me."
    Bart Simpson
    edited 2009-01-25 20:30
    None with discrete components. All of them use an IC converter chip, such as the FT232R.
    edited 2009-01-26 00:21
    I use an P2N2222 - just be careful to get the correct pinout (the older 2N2222 used a different pinout).
    · Emulators (Micros eg Altair, and Terminals eg VT100) - index
    · Search the Propeller forums (via Google)
    My cruising website is: ·www.bluemagic.biz
  • RaymanRayman Posts: 16,231
    edited 2009-01-26 00:34
    Has anybody tried using MProg to invert the polarity of the DTR signal?· It seems like it should work, but I didn't try it because Parallax didn't do it...
    edited 2009-01-26 01:21
    Yes, and apparently it works. Read about it here.
  • AribaAriba Posts: 2,697
    Rayman said...
    Has anybody tried using MProg to invert the polarity of the DTR signal? It seems like it should work, but I didn't try it because Parallax didn't do it...
    I do it also on 2 self made PropPlugs - works well.
    I have a 10nF capacitor between the inverted DTR and the RES pin.
    Maybe Parallax don't do it, because it's cheaper to add a resistor and transistor, than program each unit with MPROG (or they just not had the idea?)
    Andy
