Resetting BS2 on BOE using commands.
Dear all,
I am now using a BOE with BS2 chip on it. I know that pin 22 is the Reset pin for BS2, and should I need to reset the BS2, I just need to press the Reset button on the board.
Now since the board is on my mobile robot, I would like to reset the BOE/BS2 (or whole program) by just using commands without having to go to my robot and reset it. Is there such command?
Kindly advise.
Kindly advise.
Parallax Engineering
So it seems you can do what you want Vincezo1309, you just need to dedicate a stamp pin to it.
I'd still use a resistor (1k maybe?) between the stamp pin and the reset pin to prevent any possible problems.
Connecting it might be a pain... you may be able to get the lead of the resistor (or a very small wire) in the stamp socket beside the leg of the stamp if your VERY careful... remember,
those stamp pins are very fragile!
Note: I've never done this so I may be totally wrong about everything... I'm just guessing based on what Chris said.
