This Weekend's Project : Using A Stamp To Read Another Stamps DEBUG Output
All,
I have several Stamps working together, and I often move·my PC connection from·one Stamp to another so I can see the DEBUG output. This is getting tedious.
One of·my Stamps drives a large LCD (7" diag) display, so I'd like to display·the other Stamp(s) DEBUG output on the LCD.
Can I·connect the PCO/SOUT on the Super Carrier to an input pin on the Stamp that has the LCD? and then use·SERIN·to read the other Stamp's DEBUG·output?
This may be a completely looney idea as I've only had 4 cups of coffeee so far today...
John Burrow
San Diego
John Burrow
San Diego
The problem with doing this is there is a lot of data sent in the DEBUG screen. Your BASIC Stamp would not know what data it was getting and how it was formatted. For an SX chip it could handle the data one byte at a time, but at 9600bps the BASIC Stamp won’t be able to deal with a stream that fast. Take care.
Parallax Engineering
Is this a matter of convenience or functionality? Is there some reason other than displaying DEBUG output that you are doing this? They have those A-B-C-D switch boxes where you should be able to connect four (or maybe more), DB9 connections (from your Stamps), that go to one destination (your PC). Then you can switch between them manually without manipulating connections.
One example: http://www.trianglecables.com/db9-4-m.html
via DEBUG.
Evol Bay Link
These are battery [noparse][[/noparse]or wall wart] powered and have a 'dumb terminal' program build into them.
I used to use them [noparse][[/noparse]still have a couple around somewhere] to work on old school 'main frame' systems back in the day.
Or go wireless ... Bluetooth RS-232
I typically just use a single pin and send my debug info to a serial LCD module
Smile ... It increases your face value!
Post Edited (MrBi11) : 1/24/2009 3:23:35 AM GMT
