. Multiple VGA Displays - "Heads-Up-Display" Project Discussion.
Is it possible to drive multiple VGA displays with propeller? If so would it be possible to run three displays? I've been interested id making a digital dash display for my car. that will display all the usual things you find on your dash but in a more fancy way and due to the dash configuration I wouldn't be able to fit one large display, but would be able to arange two or three 7" displays in the space i have available. i know the propeller has the power to hands the graphics as these would just be simple gauges, and information display the could show diagnosis info from the ECU.
has anyone ever tried to run more then one display off the propeller?
Post Edited (marzec309) : 1/27/2009 9:08:09 PM GMT
http://forums.parallax.com/forums/default.aspx?f=21&m=264369
Post Edited (marzec309) : 1/25/2009 11:27:23 PM GMT
I have been looking at a similar concept...wondering if you are using the ELM chips for OBDII, would be interested in sharing info and code on this project. My knowledge of the Prop is based mostly on what I have read in the Hydra book. I am with Mike Green on this though....the memory is going to be tight for two displays up at once.
As for the OBDII, I'm planning to use a Microchip MCP2551 CAN Transceiver. I found a site that covers the CAN protocal here:
en.wikipedia.org/wiki/On_Board_Diagnostics#OBD-II_Diagnostic_connector
and here:
en.wikipedia.org/wiki/OBD-II_PIDs#Bitwise_encoded_PIDs
So the software side of the OBD interface looks pretty easy and should be able to pull most of the sensor data right from the ECM. Now, I've used a lot of the Basic stamps in my projects, but the Prop is going to be new to me. From what i hear the learning curve is not that bad. As far as sharing code, I would love to when I get to that point. Two minds are definitely better then one.
Paul Baker
Thomas Talbot, MD
Gunpowder, MD, USA
You shouldn't need drivers for the MCP2551. as this chip is a serial to CAN Bus Interface. Any serial connection will do the trick.
Yes, that has been a thought. One each as display drivers, then a master unit...
Yes, I am aware of those laws, But the AV connection to the Heads-Up-Displays(Hay I just came up with a good name for my project.), was implemented so I can feed the signal from the GPS. This would be allowed by law(I think?). And will probably have Code to do what you suggested, So the only signal that will be allowed on the Heads-Up-Display, while in gear will be the GPS.
And yes I have gotten a little of subject with my original post. Thus i have edited the Subject for this post. I'm still interested in info for Dual VGA's.
Post Edited (marzec309) : 1/27/2009 11:49:56 PM GMT
http://www.slashgear.com/century-japan-lcd-4300u-43-inch-usb-monitor-1018916/
Might it be possible to use the USB interface on the Prop Demo and Hydra to drive something like this?
Right. But that's not really bad news. The Propeller develops thrust enough to emulate a USB host. Even an AVR ist strong enough...
Oops! I posed the next challenge.
Airspace V - international hangar flying!
http://www.airspace-v.com/ggadgets for tools & toys
