Suggested chips for input expanding ?
Hi all
Have you some suggests, for the best chips for expand inputs, to a propeller system.
Thanks in advance.
Regards.
Alberto.
Thanks in advance.
Regards.
Alberto.
Saludos,
Ale
the ones you get here: http://www.microchip.com/ParamChartSearch/chart.aspx?mid=11&lang=en&branchID=11034
What you suggested looks good, also I could use a simple couple of HC165's, but what could be the advantages/disavantages of each of them ?
I only need to expand inputs, 32 I/O are getting short for me usually, also, I could use a dedicated COG for that, no problems.
Expanding 16 inputs from two or three pins are good enough for me, but which is the best, or the "nice" way to do it.
Chagracia !!
Regards.
Alberto.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Quicker answers in the #propeller chat channel on freenode.net. Don't know squat about IRC? Download Pigin! So easy a caveman could do it...
http://folding.stanford.edu/ - Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
The i/o expander chips are more flexible, usually allow a mix of input and output, may have more i/o pins per chip. They may also be able to latch a fast input signal or trigger on a pulse edge so the signal is not missed. The down side is that they are more complex to use, more expensive, and harder to source, and usually slower than the logic chips.
If you just want to build a small system which runs without great programming take the '165. If you want a fast system take the '165. If you want to be flexible regarding input or output that the MCP230XX. If you need many inputs take the MCP230XX.
I2C? SPI? Your choice! Have not yet looked into their advantages or shortcomings.
Airspace V - international hangar flying!
www.airspace-v.com/ggadgets for tools & toys
Answers were very clear & great !! .
Due I will only need about 16-24 inputs more, relative fast, low price, & easy to find, seems to be so the HC165 the perfect choice for my situation.
Thank you all again !!.
Regards.
Alberto.
Timothy is using the PCA9555 in the carrier board shown in the link.
I just wired up a MCP23017. So far, I am quite impressed. Quite easy to use.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto for SunSPOT, BitScope
www.tdswieter.com
So seems to be PCA, MCP, HC165, & some microcontrolled possibilities.
Now so, don´t forget another propeller solution acting as I/O, serial port or I2C controlled, programable, flexible, but not cheap.
Anyway, I prefeer hardware solutions instead microcontrolled solutions (less headaches).
As I said before HC165, did win for me this time.
Thx all !!
Regards.
Alberto.
