Another example of a poorly designed battery powered propeller based product
william chan
Can you guess what it is?
Somehow it looks unprofessional, more like a student project.
Any suggestions on how to make the product look more presentable?
www.fd.com.my
www.mercedes.com.my
www.fd.com.my
www.mercedes.com.my
With the Propeller's surprisingly efficient power design and some smart circuitry, the entire board's average current consumption is only 140 micro amps !.
This is amazing, considering that that Propeller NEVER goes to sleep at all times.
At this current consumption level, I estimate the 2 AA alkaline batteries can last 12 months.
www.fd.com.my
www.mercedes.com.my
·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
- Bjarne Stroustrup
For the 1st batch, we made 10 units for beta-testing.
I am still not satisfied with the outlook, so version 2 will naturally see some changes. (hopefully improvements.)
It is a chicken and egg problem.
We can't finalize the board design unless we can finalize on the casing.
On the other hand, we can't finalize the casing until the board has been finalized!
If we finalize on a board too early, the casing will turn out too bulky or ugly.
If we finalize on a small slim casing, the final board may not fit.
Designing around a good casing is difficult.
Even a simple task of centralizing the PIR sensor to the center of the casing may take days if your PCB is compact.
Anybody facing similar kinds of problem?
www.fd.com.my
www.mercedes.com.my
Post Edited (william chan) : 1/23/2009 1:55:16 AM GMT
I know a lot of people use Altoids boxes....
- Bjarne Stroustrup
do you know a design-university ?
The students need projects to get examined you need a goodlooking case
so come together
Maybe you can initialize a design-contest at a highschool
best regards
Stefan
I have used off the shelf cases and dressed them up with laser labels. If you have seen some of my products I have featured on this forum you might like to know that the labels for the prototypes are printed onto heavy duty laser label paper on a color laser. The label is polyester based I believe and resistant to water and oils, tear proof, weather resistant etc. The toner bonds to this very nicely and looks exactly like the real thing. I pick them up at the local office supplies. Try AVERY L7067 for A4 sized sheets or the equivalent. Use OpenOffice Draw to create the labels as it allows precise positioning etc. You would be surprised what a difference a smart label makes.
This is a case I have used with the Prop which has a battery compartment for two AAs plus a window for IR leds.
www1.jaycar.com.au/productView.asp?ID=HB5610&CATID=5&keywords=&SPECIAL=&form=CAT&ProdCodeOnly=&Keyword1=&Keyword2=&pageNumber=&priceMin=&priceMax=&SUBCATID=644
This case uses a laser label.
http://forums.parallax.com/attachment.php?attachmentid=57690
*Peter*
Yes it is. But it is the smaller 150MB or so case, not the larger 400MB case.
Do you know where to buy such cases without buying the DAT tape?
What are Altoids boxes?
www.fd.com.my
www.mercedes.com.my
- Bjarne Stroustrup
You are so smart.
It is designed to switch on the air conditioner when you enter the room and switch it off when nobody is around for 10 minutes.
Simple but effective energy saving device.
www.fd.com.my
www.mercedes.com.my
www.fixup.net/tips/pktamp/original.htm
- Rick
If you need something more production-ready, I suggest a project box that screws together. The PCB doesn't necessarily have to fit like a glove.
How you approach this depends on your expected sales volume. Start with an off-the-shelf project box, design your PCB to fit and set up a drilling jig for the holes. Then if you sell enough of those, go to Protomold or some other rapid tooling source and have a custom box made.
- Bjarne Stroustrup
- Bjarne Stroustrup
Parallax Engineering
- Bjarne Stroustrup
If you hate to say it then why say it?
If it's not a Prop then it wouldn't be on this forum and it wouldn't be as much fun either, and neither would we be discussing it. Besides even if you prototype it with a Prop there is still nothing that stops you from doing a production version with something cheaper after you made a functional unit.
However, I have designs which I know I can handle using a cheaper micro but for the sake of a few dollars I choose to use the CPU of my choice, the one that I have abundant tools and software for as well. Besides, I hate debugging conventional micros. If I did a production version of William's cool gadget (I will have to make one myself) then I might look at a small MSP430 mainly for battery life. But then again, as William pointed out the Prop does a surprisingly good job in that department too.
Viva la Prop
*Peter*
You have a keen eye for detail...
The IR detector is used to record the equipment's IR pulse train during program mode.
It is powered off to save power during normal operation.
This way, the product can be used for any air conditioner brand.
www.fd.com.my
www.mercedes.com.my
Post Edited (william chan) : 1/23/2009 4:24:55 AM GMT
I think the coolest thing about this gadget is that it is completely wireless.
Just velcro it near the AirCon and that's it!
SRLM,
I think smaller batteries (button?) cannot handle the IR play current, which is targeted at 80mA (short time) and last one year.
I can't use SMD Prop, because the Prop is the most expensive part in the product.
We only plug in the Prop just before shipping.
Ken,
In a way, you are right, the Propeller is an overkill. I use only 1 cog to save power. Can I get a discount if I use only 1 cog?
But when viewed in another way, the Propeller is not an overkill, because the SX could not handle this project.
That is why I asked for the TinyPropeller. No battery powered application is going to use 8 cogs.
It's a pity because the Propeller actually has a lot of battery application potential, not many people realize it.
To implement IR record and playback for all air-con brands, I need at least 600 longs (2400 bytes) of ram AND eeprom just for the pulse train storage.
EEProm alone is too slow.
Does the $0.5 Freescale have more than 2400 bytes of RAM?
www.fd.com.my
www.mercedes.com.my
Post Edited (william chan) : 1/22/2009 11:40:18 PM GMT
It would be a pity if the Propeller is only used for prototyping and never for mass production.
How would the price of the Propeller chip come down then?
www.fd.com.my
www.mercedes.com.my
As to your RAM requirements, there are I2C RAM chips mentioned in other recent posts on this forum that would probably help you there, and you would still be ahead.
Don't get me wrong...I'm a big fan of the Prop, but as an engineer you have to realize that there are more efficient ways to do some things. Business is business.
- Bjarne Stroustrup
PM me for more details.
www.fd.com.my
www.mercedes.com.my
