DIY Laser graphics?
Hi-
As a sort of side project, one of my professors is thinking about creating a laser-based display of live seismic activity on the outside wall of a new building on campus.
The idea is basically a giant oscilloscope where the input is driven by some sort of seismometer. Now, we were looking into various methods of projecting laser images. We think we can do slow ones (where the dot moves visibly without a tail) using some servos. However, then one couldn't really see the waveform. My professor said he was quoted $25000 for a real laser projection system, which agrees with my research on the subject.
Is there a simpler, cheaper way (say, glow-in-the-dark paint or something) that can create the tail effect, or even a proper waveform, using (preferably) a blue laser?
Rafael
You've got to play the game.
You can't win.
You can't break even, except on a very cold day.
It doesn't get that cold.
~Laws of Thermodynamics~
Rafael
You can't win.
blog.makezine.com/archive/2008/01/learn_how_to_do_laser_gra.html
It could be a lot less than a "laser projection" system depending on how expensive of a projector the project would require.
-Paul
Rafael
You can't win.
http://www.maplin.co.uk/Module.aspx?ModuleNo=221731
The hard bit with rotating mirrors will be tracking an input signal like an ocilloscope does as you will have to synch the rotation speed to the timeline
to get a waveform say like a sine wave wouldnt it mean a rapid switch of direction not good with motors.
The "motor" used to position·a mirror in a laser reflecting-positioning scheme is called a galvanometer.· They're available on ebay.
